Old 05-28-2018, 01:25 PM
Frank of Denmark Frank of Denmark is offline
Default Re: CPU overload with Native Instruments
Update:
I tried troubleshooting everything. Nothing helped the cpu load in Pro tool.
But at least I narrowed it down to the new kontakt library "Session guitarist Electric sunburst". It's killing the cpu. Everything, including "Session guitarist Electric sunburst" works fine in standalone mode.
Old 06-08-2018, 01:51 AM
I just tried to downgrade OS from 10.13.4 to 10.13.3. That didn't help either. Argh!
Btw, Native Instruments forum and support suck big time (pardon my french). Maybe it's because one is used to this pro tool forum, always full of helpsome experts. : )
Old 06-11-2018, 11:25 AM
arche3's Avatar
arche3 arche3 is offline
Try vepro and put kontact in there. On some VI I have to use vepro. Native Instruments are notoriously fickle in protools. Some of them work fine and others do not. I just run all my NI in vepro inside protools now and much happier. I also use bluecat patchwork for maschine at times. That works fine as well.
Old 06-11-2018, 11:37 AM
Yes, I used DDMF metaplugin (vst), but experienced that the metaplugin used a lot cpu (ironically). Therefor I wanted to just use the aax instead. Hot damn, it's not easy.
Old 06-11-2018, 11:57 AM
arche3's Avatar
Use vepro. I think there is a trial maybe.
  #16
Old 06-11-2018, 12:53 PM
Is vepro a Vienna Ensemble thing? I'm not familiar to vienna. Can you direct me to a link? Thanks
  #17
Old 06-12-2018, 12:21 AM
arche3's Avatar
https://www.vsl.co.at/en/Vienna_Ense...O/Product_Info
  #18
Old 06-12-2018, 04:49 AM
dtmprod dtmprod is offline
I would definitely go the VEPro route. I've long quit trying to use VI's in Protools, have pulled them all out of my plugin folder. Use them all thru VEP......
  #19
Old 06-12-2018, 04:56 AM
jryser's Avatar
jryser jryser is offline
Same here. Works great across computers that are ethernetted to my main MBProR
A Rig: MacBook Pro Spring 2013, 2.8Ghz I7, 16GB RAM,
OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph GT 050 Qx3 1.5 TB drives Thunderbolt-FW400, Presonus Faderport. 10 REMOVED!
B Rig:MacBook Pro Spring 11, 2.33 GHz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph Portagig 62 portable 1 TB drive Firewired with 400, Presonus Faderport. 10 REMOVED!
I am the main songwriter/performer for Midwest Whitetail, Cabela's Deer Nation, Spring Thunder, and Northern Waters Series!
  #20
Old 01-28-2019, 10:07 PM
Intransit Intransit is offline
I hate to pile on, I'm a working film composer and totally gave up on using Kontakt in PT. VEP, sometimes I'll throw in a Kontakt if I know the library well. Not sure what happened I did many remote sessions with Avid's head tech, I've scored films in the past without VEP but it's far too much of a headache now. I know a couple other PT composers that gave up too. Takes a little time getting used to the workflow but being able to work and meet deadlines...
iMac Retina 5K, 2020, 3.6 GHz 10-Core Intel Core i9, RAM 72GB
HD Native PCIe card /// OWC Mercury Helios 3S
PT 24.3.0
FS: McDSP, Native Instruments Absynth 5, iZotope RX, Air Instruments antonis Buy & Sell 0 03-08-2018 05:25 AM
Native Instruments in PT 12.1 cpu overload? tonykitowicz Pro Tools 12 10 07-02-2015 04:24 PM
PT11 CPU overload with small number of Virtual Instruments rookie recorder Pro Tools 11 17 01-06-2015 10:29 AM
Native Instruments - xfer fee for instruments? YYR123 Virtual Instruments 3 10-13-2013 04:47 PM
TL Space Native = CPU overload Eliza Pro Tools M-Powered (Win) 5 01-21-2009 04:43 AM
