Old 09-20-2015, 11:33 PM
Matt Hepworth's Avatar
Matt Hepworth Matt Hepworth is offline
Default Weird error where MIDI goes dark each time I open session
So, I don't frequently run VI's, but I've just run into a weird problem.
Across multiple projects the MIDI on an instrument track goes dark (instead of blue) like it's inactive.
I can't figure out what's causing it, but normally inserting a new instrument track and then copying the old data over to it and then moving the inserts resolves it. Just copying the data makes the new one blue.
Pic attached.
File Type: png Screen Shot 2015-09-20 at 11.22.44 PM.png (5.9 KB, 0 views)
Old 09-20-2015, 11:49 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Weird error where MIDI goes dark each time I open session
Pic attached.
It's lost its routing to the VI. Simply reassign the routing back to whichever midi instrument it was playing.
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 09-21-2015, 12:11 AM
Chris, the insert is directly on the track with the MIDI (instrument track). Not sure how to reassign.
Old 09-21-2015, 12:28 AM
crizdee's Avatar
Set the track view to instrument. This will open a column ( same as I/O / inserts / aux sends etc) where you will see the input and output routing for the midi. The input will probably be set to "all" and the output should be set to whichever instrument you have inserted on the track. If it's still routed to the instrument then just refresh it by selecting it again. If it's not routed to the instrument then just re assign it back to the instrument.
Chris
Producer, Engineer,
www.ukmastering.com
Old 09-21-2015, 01:44 AM
Cool, thanks. Not sure why it's happening across certain projects every time, but I have a workaround...
Pro Tools 9 crashes every time I open a new session or import session data Ryan Butler macOS 14 03-23-2014 08:53 AM
Every time i re-open a session my midi keyboard stops functioning Morrowindsr8good Windows 11 01-11-2012 03:18 PM
Tracks bin open every time I open a session albee1952 Windows 5 10-04-2011 09:15 PM
HELP! Error: Midi Chunk List - cannot open session SamiD Pro Tools TDM Systems (Mac) 2 02-12-2006 03:54 PM
HELP! Error: Midi Chunk List - cannot open session SamiD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-10-2006 07:06 PM
