Old 04-25-2007, 03:40 PM
DBboy DBboy is offline
Default How do you guys do monitoring?
I have an Mbox mini with the "zero latency" mix knob thingie. Problem is, enabling record causes the dreaded software monitoring giving me the delayed signal as well. Turning down the mixer fader to zero eliminates this, however I need to hear the track when punching in. Is there any way to set Protools to disable it's internal record monitoring? Thanks and sorry for the dumb question.
-RS
Old 04-25-2007, 11:01 PM
n0v8r n0v8r is offline
Default Re: How do you guys do monitoring?
Do you have plugins loaded/enabled on the tracks you're recording against??
What system are you running? OS? What's your H/W Buffer Size??
As long as you haven't done all your editing and dialed in all your plugins for the other tracks, the best thing is to try lowering the Hardware buffer size(obvious).
Need more information.
G4 Powerbook OSX 10.3.8
PTLE 7.1
Waves Diamond,Vocal,IR1,Reason3
002,002R,MBOX1
Old 04-25-2007, 11:27 PM
StudioRhythm StudioRhythm is offline
Mute the track you're recording to. Or, if you need to hear the track you're recording to before the start of the punch, route it to a bus and automate a mute on the bus that starts at the punch-in point (since you can't use automation on a track in record mode).
www.studiorhythm.com
Old 04-26-2007, 06:44 AM
therecordinghouse therecordinghouse is offline
another option is to set up a second track to do your punch ins. on the original track select the area of audio you want to punch and hit delete. you can leave your original track unmuted, so you hear your audio up to the punch point. mute the second track and monitor from the hardware. when you are done punching, just drag and drop the punched regions onto the original track.
this takes only slightly more time than it would to set your punch IO points on a single track.
Lynn Graber
Studio and Mobile Recording, Fort Wayne, IN.
Old 04-26-2007, 10:13 AM
Ben Jenssen's Avatar
In prefs there is the choise to "link record and playback fader levels" (or something to that effect) - uncheck this box. Now set the recording tracks fader to -inf when record enabled and to desired level when not rec enabled. When you punc in, the fader will automatically drop to -inf.
IHTH
Old 04-26-2007, 11:00 AM
IHTH
that is not really what he was asking...
Lynn Graber
Old 04-26-2007, 12:36 PM
I still think my reply adresses his issue. He needs to hear the track UP to punch in point and not thereafter.
Old 04-26-2007, 02:24 PM
Yes this does indeed address the problem I was having. Thanks so much for the work-around. And thanks for the replies. I am now considering an MBox2 Pro since it has "low latency" monitoring. In the mean time, this will do.
-RS
Old 04-26-2007, 03:35 PM
Well................this does not work either! Yes you can set a seperate level for record enabled tracks, however you have to be record enabled to punch in on the track in the first place. Therefore I still can't hear the track up to the punch in point. Dang...........
Any other suggestions? Am I missing something? Thanks,
-RS
Old 04-26-2007, 05:30 PM
Be shure to be in "auto input monitoring" mode ("Operations" menu, I think).
Direct Monitoring VS PT Monitoring therecordinghouse macOS 5 11-23-2013 06:18 PM
Record monitoring level different from Playback monitoring level. sonicflwr macOS 1 03-09-2012 11:05 AM
Monitoring through Rosetta vs Monitoring through 003 Rob0214 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-17-2010 04:02 AM
Thanks - guys kbruff 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-05-2010 09:10 AM
ok guys, I got drum kits from hell, how do you guys use them? compblue 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-29-2003 06:58 AM
