Old 03-11-2009, 03:25 PM
David Khositashvili David Khositashvili is offline
Default Direct signal from DIGI 003
I'll try now to explain what I mean (sorry from my English)
So, I use digi003 and PT 7.3.1 to record live concerts (classical)
sometimes some radio stations come to broadcast live directly from my digi. They just take audio signal from me and push it on air.
I plug their cables into main outputs.
But
When I push solo or mute buttons on each channels it acts on that output also.
I need to give audio signal to radio stations without any real time mixing process. Just the dry signal.
I mean, I want to send master signal to radio before I start mixing it (muting or soloing channels)
Is it possible?
I hope I explained it well.
Old 03-11-2009, 05:00 PM
robo6675 robo6675 is offline
Default Re: Direct signal from DIGI 003
Pre-fader sends
MacBook Pro (silver) 2.5 GHz Intel Core 2 Duo - 4 GB RAM - 10.6.6 - PT9 - 003 BLA sig mod
Terrarium
HD3 Accel on a PowerPC - OS 10.5.7 - PTHD 8.0cs2
(3)192/SYNC IO/CS HEDD192/Studer A27/Neve 48 Ch. VR console
Old 03-11-2009, 07:18 PM
To expound on Robo's advice, go into the I/O setup page and create a stereo(or mono) bus that routes to a pair of analog outputs(I would choose 7&8 to keep them physically away from the main outs. Now add a Pre-Fade aux send to each track and turn up the send faders. If you are doing any mixing with the main faders, you should flip to the aux sends and set them to the same values so the radio feed(going out 7&8) matches your main mix.
How to stop 11r's direct signal to my monitors? suckamc Eleven Rack 3 10-17-2011 09:09 AM
bass direct in mbox. hot signal? CrAkD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-07-2005 02:32 PM
run a direct guitar signal out of PT to PodXT? keithl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 02-28-2005 10:54 AM
Can't see the waveform of a direct-in guitar signal? el biciclista Pro Tools TDM Systems (Mac) 13 06-07-2003 02:44 PM
Splitting guitar signal for direct recording? QuikDraw General Discussion 5 05-14-2001 10:01 PM
