Old 08-26-2020, 08:28 AM
justDoug justDoug is offline
Default Pro Tools HD 9 installer
Originally Posted by albee1952 View Post
Personally, I download everything and stash on a 2TB USB drive. Whether I intend to install or not, I will have it, just in case
Would you happen to have a copy of the installer for Pro Tools 9? I just bought an iLok license (used iLok with no account access) for Pro Tools 9 HD, but only have access to the 10/11/12 installers.
Regards,
Doug
Last edited by DigiTechSupt; 08-26-2020 at 09:10 AM. Reason: Moved off-topic post from Pro Tools 2020 forum
Old 08-29-2020, 04:25 PM
Default Re: Pro Tools HD 9 installer
Anyone...?
Old 08-29-2020, 06:20 PM
Southsidemusic's Avatar
Originally Posted by justDoug View Post
Anyone...?
Do you still need a installer for HD9? Let me know.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 08-29-2020, 06:21 PM
Anyone...?
Do you still need an installer for HD9? Let me know.
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 08-29-2020, 07:19 PM
Yes, please.
And it appears the used iLok I just bought has been "disabled"; displays with a red X in License Manager. Any idea what to do now...?
Last edited by justDoug; 08-29-2020 at 10:59 PM. Reason: Disabled, not deactivated.
Old 08-29-2020, 11:38 PM
JFreak's Avatar
JFreak JFreak is offline
It means the key is tied to another account, you cannot register it for your own. Bought the license as is, working on the key you bought it as long as the key is working, cannot transfer or upgrade the license.
Janne
Old 08-30-2020, 07:00 AM
If the ilok key is ”disabled” that is a whole other issue and you wont get to use the ilok and licenses at all so to install anything wont work if it uses licenses from the disabled ilok so until the ilok is enabled again by the previous owner or by Pace/iLok the license of PT9HD is pretty useless.
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 08-30-2020, 08:11 AM
The Weed's Avatar
The Weed The Weed is offline
You need to get your money back from the seller or get the seller to transfer the iLok account to you, provide the PT 9 HD software and transfer that software to you through Avid. If you bought the iLok off eBay, start a case if the seller won't give you your money back or won't do the transfers.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 08-30-2020, 08:21 AM
JFreak's Avatar
If they have not agreed for Transfer of Ownership paperwork, that may not work. But if the license itself does not work (disabled) then the buyer has not received what was sold.
Janne
Old 08-30-2020, 08:27 AM
Thanks for the replies. I still need a copy of the installation file for Pro Tools 9. The iLok issue should be able to be resolved by the seller. He is local so I can take it to him for synchronization/"enabling" (assuming he has access to the account associated with this iLok). If not, then I'll return it...
[IMG] code is Off
looking for pro tools TDM 5.3 installer + sn supernova777 Pro Tools TDM Systems (Mac) 5 11-11-2017 01:23 AM
Pro Tools 12.3.1 T installer adam79 Pro Tools 12 10 12-07-2015 08:51 PM
The installer was unable to launch the PACE system files installer - Help please buzz302 Pro Tools M-Powered (Win) 3 02-14-2012 09:05 AM
Is there a seperate Windows 7 64 PT 8 installer (other than WinXP installer) RuffinMedia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-26-2010 09:43 PM
