Old 10-28-2012, 05:06 PM
ncmetalguitar88 ncmetalguitar88 is offline
Default Trying to use external keyboard sounds
I am trying to use the sounds from my Casio Keyboard in Protools 10LE, but all I can seem to do is use it as a control surface for the various plugins that I have.
Would appreciate if someone could help me out. I already looked at the PDF manual and all I could find was how to turn my keyboard into a controller.
Old 10-28-2012, 06:14 PM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
Default Re: Trying to use external keyboard sounds
First things first, does the keyboard have a midi in jack?
- John
If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound?
Old 10-28-2012, 06:41 PM
It does. I am connected to the Midi Out on the keyboard to the Midi In on my Eleven Rack interface. I currently have an Instrument track processing Midi data through Expand for some symphonic type stuff, but I like the sounds on my keyboard better.
I can control the plugins I have (Expand2 and the like) but I want to use the sounds off of my keyboard.
Old 10-28-2012, 09:10 PM
CalebB CalebB is offline
Default
To use the sounds on your keyboard you need to use a 1/4" cable coming from the audio output (not MIDI) from the keyboard plugging into a 1/4" audio input on your Eleven Rack.
Old 10-28-2012, 09:31 PM
Does that work for sequencing and writing midi? I am not a keyboard player, so I have to map out my tracks.
Old 10-29-2012, 06:02 AM
The basic setup is this:
Get another midi cable and go from the midi out of the eleven rack to the midi in on the keyboard.
Connect the audio out(s) from the keyboard to the line inputs on the eleven rack.
Create a plain midi track, set it's output to the eleven rack's midi output port, and channel 1.
Create a stereo audio track and set it's inputs to the eleven rack line ins. Record enable it.
Set up the keyboard so it receives on midi channel 1.
Draw some notes on the midi track, and play them back to see if you get sound.
The unknown is configuring the keyboard to recieve midi, it's different for every one.
- John
Old 10-29-2012, 08:25 AM
Thanks for the info! I will try this as soon as I get the chance.
It is a pretty basic keyboard and doesn't have a GUI other than a musical staff, fingering positions, and what sound bank you are on so I hope that it just receives the midi data automatically.
Old 10-29-2012, 09:08 AM
Somewhere in the manual there is hopefully a midi implentation chart. This will tell you what controller numbers/values, program changes, and or midi channels are used to automate patch changes, effects etc. This way you can fully automate it from pro tools.
- John
Trying to use external keyboard sounds ncmetalguitar88 MIDI 0 10-28-2012 05:00 PM
Built in sounds in midi keyboard mike1234 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-10-2009 04:57 PM
How do i use my motif sounds from the keyboard to pro tools? babymanuel MIDI 2 11-23-2007 11:50 AM
How To Play VST Sounds On Pro Tools Keyboard? Aedryan Methyus Virtual Instruments 31 07-12-2006 08:29 AM
OT: Reggae keyboard sounds... how? tommydee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-18-2002 12:44 AM
