Old 10-25-2012, 04:37 PM
ncmetalguitar88 ncmetalguitar88 is offline
Default PT10 "Cannot connect to Eleven Rack"
This has just started happening to me and I do not know why.
I will turn on my 11R, then start up PT10LE. PT loads up fine, so I select a session and it loads normally until it starts to load the 11R plugins. From this point it sits for a minute, then says "Failed to connect with Eleven Rack. Would you like to try again?" Doesn't matter what I do so I shut down PT, turn off the 11R and try it all again. Sometimes it works sometimes it doesn't.
Not saying they are related, but I did not download the PT update that was just released.
I get this message randomly it seems, as sometimes it works just fine. It also seems to only happen right as I start up PT. All of the connections are firm and I re-downloaded all of the drivers.
Anyone know what could be causing this?
Old 10-25-2012, 05:09 PM
Benoni's Avatar
Benoni Benoni is offline
Default Re: PT10 "Cannot connect to Eleven Rack"
have you tried another USB port?
have you tried another USB cable?
Windows? OSX?
Old 10-25-2012, 06:44 PM
I am using the USB that came with the 11R, so I hope that isn't it. I do not currently have a different one though. I will have to try that and the port idea next time it happens.
Also I am on Windows... which, at least if I asked the people at my recording school, would be the source of all of my problems. One way or the other. Lol.
Old 10-25-2012, 07:01 PM
Also, I just tried to connect and the exact message is
"Communication with the "Eleven Rack" has experienced and error. Would you like to re-connect?"
Old 10-28-2012, 12:47 AM
zedhed's Avatar
zedhed zedhed is offline
Have you tried re-installing 11R drivers?
Reinstall with 11R turned off then reboot with it switched on.
Too much blood in my drugstream
Gigabyte X99 SOC Force Mobo Bios vF6d
Intel Core i7 5930k socket 2011 v3 @ 3.50GHz
32GB DDR4 Crucial RAM
System: Samsung M.2NVME SSD 960 Evo
Record: Samsung M.2NVME SSD 960 Evo
Samples: Samsung SATAlll SSD 840 Pro
Storage: 2x Samsung SATAlll SSD 840 Pro
EVGA GeForce GTX 750 Graphics
PT 11HD (v11.2.1) Omni s/pdif w Eleven Rack
HD 96I/O
Win 8.1 Pro
Old 10-28-2012, 12:39 PM
Thing is most computers like to have all their peripherals connected and powered up before they (the computer) go through their bootup sequence. Especially on Windoze. Hot swapping and hot plugging usually doesn't work in Windoze. So - power up your 11R (and any other peripherals) BEFORE powering up your computer.
Jack
QAPLA!
Old 11-02-2012, 09:09 PM
zedhed's Avatar
Yep, I've found powering audio interfaces after boot up seems to corrupt the drivers somehow....and not every time...sometimes yes and other times not. Re-installing the drivers fixed it for me.
Since powering interfaces on before boot up, I've had no problems.
HD 96I/O
Win 8.1 Pro
Solution to "Track could not be record-enabled" issue with PT10 and Eleven Rack spankyq Pro Tools 10 8 04-20-2015 08:19 AM
Eleven rack (11R) slow booting past "setting up midi" Edleigh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-25-2011 09:44 PM
"Eleven Rack" window gone in PTLE after upgrading to Lion? Deny Eleven Rack 6 10-03-2011 07:23 PM
Do I need the "Transfer Ownership Audio" form to sell my Eleven Rack? acmost General Discussion 5 04-16-2011 12:07 AM
Eleven Rack "Unable to locate Digidesign hardware" efisch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-07-2011 03:18 PM
