Old 01-27-2008, 04:20 PM
joeshambro joeshambro is offline
Default Digi 002-R Analog Outputs - Low Level/Distorted
I recently installed an analog summing mixer to use with my 002-R in my mix studio. When sending audio from a channel to one of the eight analog outs, the signal is very, very low -- hardly audible at all -- and very distorted and buried in noise. It's like this on all eight outputs. A little jiggling of the output cable will sometimes yield a result, but generally it stays very, very quiet and distorted.
At first I thought it was a problem with the summing mixer, so I borrowed a different one and tried -- same result. I tried all new cables, no luck. I tried listening to the channel directly, and it's still there -- very, very quiet (barely audible) and highly distorted what I can hear.
I'm matching levels correctly -- +4db in on the summing bus -- and having tried just about everything else, I'm at a complete loss.
Help!
- Joe
Old 01-28-2008, 03:28 AM
Phil Jeffers Phil Jeffers is offline
Default Re: Digi 002-R Analog Outputs - Low Level/Distorted
This has me stumped... have you double checked the I/O window - hit default and make sure that all the analogue outputs are selected. Have you tried using the main outs rather than monitor outs? Are you using TRS connectors? Make sure that the faders are up in the Mix window also... option clicking the fader will put it at unity (0dB).
Old 01-31-2008, 06:09 PM
tried just about everything -- still very very frustrated!
Old 02-01-2008, 08:32 AM
stoneinapond stoneinapond is offline
Help!
- Joe
Prior to installing the summing mixer, how were you monitoring the audio out of Pro Tools?
You mention that jiggling the cable helps. Helps how? Do you get intermittent full signal?
And what do you mean by "I tried listening to the channel directly"?
Old 02-01-2008, 08:36 AM
What summing mixer are you using?
Old 02-03-2008, 09:09 AM
TbagWhitey TbagWhitey is offline
I also am having the exact same problem. I think that it must be a hardware failure because the right channel distortion is coming from all outputs (tape out, headphone, etc.)
Old 02-03-2008, 01:57 PM
dmm dmm is offline
Using balanced cables on the outputs will kill the noise on the 002r.
Old 02-03-2008, 03:47 PM
Are you using TRS cables? stereo, not mono?
Old 02-10-2008, 02:24 PM
I have also tried all new cables without luck. I plugged in an MBox that I own and the problem disappeared, which makes me think its an internal failure. If anyone figures anything out keep us posted.
Question on digi 002r analog outputs kierkegaard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-21-2013 02:04 AM
Digi 003 Rack Analog Outputs (Impedance?) lowlights 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 05-02-2012 07:51 AM
about Digi 003 outputs level, and TRS patching jaunmanuek 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 08-10-2009 06:20 AM
Digi 002R Analog Outputs boost low frec and more....HELP! polen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-01-2008 01:27 PM
Need more analog outputs on Digi 001... richy5150 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-24-2005 09:34 AM
