Re: CCC question
Yes, of course. Sorry.
My system is set to norwegian, and disk tools is just my translation of its norwegian name. Quote:
I just double-checked. You can add and manage partitions on any mac disk without losing data. What do you mean by "system drives" anyway? The drive is just a drive. It can contain one or many partitions, and they, in turn can contain a bootable system or not. The main difference between Disk Utility and TM or CCC is that DU makes disk images (.dmg), and the other two makes folder directories. It means that DU can't do "incremental backups", but also that its disk images are true images that when restored is byte-by-byte precise, resulting in problem-free boot partitions. Not so with CCC and TM. And a disk image is just a file you can place anywhere. |
Re: CCC question
Re: CCC question
Installed PT11.3.0 and the Avid instruments. Tried a couple of audio only sessions and they seemed to take a bit longer to load then in OSX 10.8.5 or OSX 10.9.5 but they payed okay. Installed updated drivers for my MOTU MIDI Timepiece AVUSB. Installed Komplete 9 programs (Kontakt, etc.) and pointed them to where my sample data was (I had used Migration Assassin to move the non-program NI stuff from my ML partition). Tried a PT session that had 5 audio tracks and two tracks with unrendered Kontakt instruments. Not fun. PT cpu meter at idle was bouncing around at 40 percent and while playing bounced around at 95-97%. No PT errors though. This same session on the other two OSX partitions idles at 14% and maxs out at 20%. Tried a session that had NI Guitar Rig 5 on an insert and that locked up PT but that's a known issue that NI has alerted users about that they're working with Avid on this. Still no fix though and it's been months. My thoughts - going back to Mavericks or ML for now. Keeping the Yosemite partition though. |
Re: CCC question
I had the same results, between my first initial install and my test, they both behaved differently. One had about 30% with all my normal Waves plugs loaded and 16 tracks or so, the other hovered around 18%. Thinking going to go back and test more on ML then finally install PT 11.2.2 on my system drive. Sure hope things get a great deal more stable, feel like I wasted my money on upgrading to POT 11!
FBR recording - https://www.facebook.com/fromthebase...cordsrecording @FBRrecording - Instagram Rig MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors |
Re: CCC question
That you lose data if you add a partition to a drive with no system on it. |
Re: CCC question
It's what OSX disk utility warns about that you may lose data when moving/adding partitions on a non-system drive. And it makes sense really. Whether that's wrong or not is not for me to say.
fruity loops in pro tools question...not regular rewire question | nutrinoland | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-23-2010 12:39 PM |
quick question - Mbox Mini question - i forget | JRup | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 10-18-2009 02:55 PM |
Another optical expansion question question for boffins | Che_Guitarra | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-23-2008 11:21 PM |
General Venue Automation Question - (Maybe dumb question) | TwoPort | VENUE Live Sound Systems | 5 | 12-21-2007 02:41 PM |
Chipset Question/Hard Drive Question | andrewkstone | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 07-26-2006 08:15 AM |
