Oxygen 8 v2 and Pro Tools
Is there a Pro Tools template that can be used with the Oxygen 8? How can I get those codes? Does anybody know how to get them?
Re: Oxygen 8 v2 and Pro Tools
I gave you instructions on this in your other thread.
The "codes" you are looking for are
As a matter of fact, the Oxygen 8 has the same controls as the Axiom, so the assignment should be identical.
All you have to do is follow the instructions on the tutorial page I linked you to, download and install the enigma software, and then reprogram the keys with those values.
Thanks again..Im a 86 yrs old drummer..Im a little slow (haha, kidding..) I think I tried that last night..I followed the instructions, I downloaded the Enigma software, but it didnt work.. I will try again tonite. Surely, i did something wrong. Also, when I select the JL Cooper CS-10 profile on the Peripherals list, there is a message that says that the Original MIDI device cannot be found. (something like that) I dont know if that has something to do with it..
Is your oxy 8 installed properly? Are you selecting the oxy 8 on the "Receive From" and "Send To" section of the peripherals dialog?
yes i did.. the oxy 8 works fine if i use Sample tank 2. I selected the Oxy 8 on the recieve and send settings.. If I open the Peripherals menu is selected.. but when i press OK , it gives me the message.
Did you download the proper Legacy MIDI controllers for your version of Pro Tools? You mentioned in your other thread that you were using Pro Tools 7, but is that 7.0? 7.1? 7.3? There are different legacy MIDI controller versions for each; did you download and install the right one?
I have PT 7.0 .. I downloaded - Legacy MIDI Controllers - Pro Tools 7.0-7.1 Windows- 1.94MB
This should be the correct one right? |
Yes, that should be the correct one.
Do you have the program loaded up on the oxy? That's the only other thing I can think of that might be wrong. Also, can you please post the exact error message you are getting? "Something like that" is really hard to troubleshoot.
well.. when you say software you refer to the Enigma right? Maybe thats the problem.. i did not make any procedure at all.. just downloaded it and installed and open it. I selected the Oxy8 v2 from the Devices list. I dont have the exacly message because Im at work now. I will be at home within 5 hours. So i guess that i will try everything tonite again. And I will write if i have a problem. Thank you VERY much!
hi .. im still having dificulties with the oxy 8. I already set up everything and it works.. the transport buttons work. But, they are not correctly assigned. The REW button acts like the STOP button. The FF acts like the PLAY. Im setting all the CC corectly the way you posted it. What am I doing wrong? haha..
m audio oxygen 61 in pro tools 10.3.3 | 201spotlite | MIDI | 0 | 03-02-2013 05:41 AM |
Oxygen 8 with Pro Tools 10? Help? | Ezrag | MIDI | 2 | 01-13-2013 02:36 PM |
oxygen 49 3gen and Pro Tools 9 | tim.bassanello | macOS | 1 | 07-31-2011 09:22 AM |
Oxygen 49 not working with Pro Tools LE 8 on 002 | livingspacestudios | MIDI | 1 | 12-07-2009 01:57 PM |
M-Audio Oxygen compaitable with Pro Tools LE? | summersjon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-03-2008 11:02 AM |
