Old 04-30-2011, 12:37 AM
slyteknikal slyteknikal is offline
Exclamation Mbox 2 Standalone Drivers for Windows 7 32Bit
Hi!
I have recently put Windows 7 32bit on a PC and trying to get my mbox 2 working on it.
I have tried these drivers, http://secure.digidesign.com/service...&localeCode=en
they work, but they are glitchy when running Ableton, Reason and Fruity Loops. I have seen people have got the 7.4 drivers working on 7, but I can't!!
I have been using XP SP2 for a long time now works fine, I was just wondering if anyone knew where I could find standalone core audio drivers for the mbox 2 with Windows 7..
Any help would be greatly appreciated!!
Thanks x
Old 04-30-2011, 01:01 PM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Mbox 2 Standalone Drivers for Windows 7 32Bit
Core Audio drivers are for Mac.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 04-30-2011, 01:56 PM
djcreation24 djcreation24 is offline
I have tried the Windowo version it does get glitchy in Cubase, but it worked fine in Reason and FL. I'm not really sure what the problem is but it might had something to do with very low latency? Or somehow the program don't like me. For me to get that fixed, I uninstalled PT 8.4 LE and installed it over again. I deleted the driver and I just let Windows find the driver for me. It should give you the "Asio digidesign driver." If you have 8.4 LE already, there's an upgrade 8.5 LE on here. Use that! :P
Old 05-01-2011, 05:48 AM
I might just buy the new Mbox 3 they must be compatible with Windows 7
Old 05-01-2011, 05:57 AM
thanks for the help lol........ very helpful
Cheers,
Old 05-01-2011, 06:15 AM
Mbox 2 is compatible with both Windows 7 32/64 bit. Try deleting the Mbox 2USB family drivers and uninstall PT and every components. Do a registry clean use Ccleaner. Restart computer and install PT again. This time let Windows find the drivers for you. It might not find it for you, but after the installation process do an update to 8.5 LE. Look at the top of this forum. Or if you still have PT installed, just do a straight update to 8.5 LE and Windows will probably delete the old drivers and find the new drivers for you.
Old 05-02-2011, 04:15 AM
oxelamp oxelamp is offline
download 8.0.4 beta drivers for win7. or use asio4all.
digidesign asio is broken from 8.0.4 and still are with the latest drivers.
Old 06-01-2011, 05:02 AM
thanks! gonna try now :)
Old 06-01-2011, 06:10 AM
AWESOME!! Works great! thanks mate!
for anyone else, drivers are here on this link at the bottom of the page
http://avid.custkb.com/avid/app/self...p?DocId=362875
also you need asio4all
available on this link
http://asio4all.com/
mBox 2 Standalone Drivers for XP pro larryloo Pro Tools TDM Systems (Win) 0 03-01-2012 07:50 PM
Mbox 2 standalone drivers Venta 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-19-2010 06:20 AM
Is standalone Windows Audio Drivers v8.0.3 compatible with WINDOWS XP 64 ? VonHelvete 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-28-2010 10:01 AM
Windows 7 + Mbox Mini + Standalone Drivers = ?? FirstStep 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 11-24-2009 09:33 PM
Mbox 2 Standalone Drivers for Windows Vista Yung Cutta 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-01-2009 03:51 PM
