Need help assigning 8 outputs of M-Audio firewire 410
Using a Mac G4 1.2gh dual processor. Running Pro Tools M-Powered 7.3.1 Need HELP!!!! Assigning 8 outputs of firewire 410 to Mackie 24-8 console. Can't seem to get a handle on it from the 410 user manual. Is anybody out there? S.O.S.
Re: Need help assigning 8 outputs of M-Audio firewire 410
Thanks for responding Chris. I did'nt explain my situation when i first posted the thread. Yes I do want to mix down thru my Mackie console. I have eight tracks recorded in Pro Tools, and am having a problem assigning each track to an individual output on the Firewire 410 1-8. I love the feel and sound of my Mackie console, it has'nt failed me yet, even when I was all analog. Now I'm combining
the two analog and digital. Could you or anyone reading this please help. Thanks again. Illyphilly. |
Ok, I'll give it a shot. I am looking at the edit window if it matters. Make sure that you have the i/o section showing by going view>edit window>I/O. Next, go to setup>I/O and click default.
If you go to each of your 8 tracks, under the i/o column you should have (from top to bottom): 2 grey rectangle boxes, then 2 black boxes for volume and panning and then a fader box. The top grey box is input and the one below it is for output. Click the output box and you should be able to go to interface> then choose from either stereo outs or each out as a mono. J |
Thanks Jrummer, this may be the info I needed. i'll give it a try and let you know the results. Thanks again. Philly
8.1 Problem assigning outputs | MX582 | Pro Tools TDM Systems (Mac) | 0 | 09-29-2010 02:20 PM |
Assigning Strike Outputs to Audio Channels | Logichead | Virtual Instruments | 1 | 12-13-2007 10:16 PM |
assigning outputs shortcut... | usd | Tips & Tricks | 2 | 11-10-2007 06:42 AM |
Random re-assigning of outputs! | conwayrecording | Pro Tools TDM Systems (Mac) | 4 | 03-28-2007 04:41 PM |
How? Assigning Multiple Outputs? | a2zproductions | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 09-14-2004 09:51 PM |
