Old 08-08-2013, 04:52 AM
11miles 11miles is offline
Default Exact same song start, timecode and Bars/beats
Iam going crazy!
Been working inside PT for some years now, but have failed to learn this (seems easy enough task).
I am composing a song for a trailer. And would like the first frame to line up to first beat of the song.
One way would be to use the start of the session, but what if i have 3 versions inside one session that starts on i.e. every hour.
there must be something like ''insert time and bar aligned'
help please,
...me failing english? That's Unpossible
_____________________________________
Old 08-08-2013, 08:01 AM
demodigi demodigi is offline
Default Re: Exact same song start, timecode and Bars/beats
Personally, I would use one session per version, and use the "Move Song start feature" (menu "Event/Time Operations/Move Song Start") to align the 1st bar of your song to a particular timecode/frame.
But you can also use a trick for your 2nd, 3rd version in the same session :
- Just before the 2nd version start point, you can locally change the tempo (up or down) to align the bar/beat to a particular frame. It won't be numbered bar1 but it should do the trick unless you change tempos in the previous version (everything would move in this case). Not ideal at all, though...
Macbook Pro (Core2duo 2,4GHz RAM4GB SSD)
MacMini (Core i7 Quad@2,3GHz RAM16GB SSD)
PT 10.3.10 + PT12.4 / VEP5.3.1 / MacOSX.9.5 (MBP)
PT12.4 / VEP5.3.1 / MacOSX.11.1 (MBP)
PT 10.3.10 / PT11.3.2 / PT12.4 / VEP5.3.1 / MacOSX.8.5 (MM "Production" on SSD)
PT 12.4 / VEP5.3.1 / MacOSX.11.1 (MM "test" on HDD)
RME UFX (USB2 with MM and Firewire with MBP)
+ Vienna Ensemble Pro Server on PC Q6600/8Gb/Win7-Pro64-SP1
Bars and Beats GTTTT Pro Tools 10 4 04-05-2013 04:51 AM
Timecode and Bars:Beats in same session nucelar Post - Surround - Video 4 08-06-2009 02:42 AM
synching bars & beats with timecode therockstar30 Tips & Tricks 0 09-05-2006 04:57 PM
Song Start - Can't spot to timecode StadiumRocker Post - Surround - Video 5 03-04-2005 01:28 AM
bars and beats.....its off Mikchek 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 02-03-2003 01:47 PM
