Old 03-15-2011, 05:04 PM
11miles 11miles is offline
Default ExpressCard Firewire, recommendations
I run PR9 on an early 2008 MBP 2.4, with FF400.
I used to run esata disks, but got a cheap expresscard.
I would like to avoid that and have no problems wiht my FW800 GRaid system.
Anybody using anything that would care to recommend?
I have look through the avid site and rme sites, nothing in particular, but the SIIG card for 003 users.
I also noticed, not a lot of Expresscard users. Shame..
I guess that is the reason Steve decided to put it out of the nev MBP (17' being excluded)
...me failing english? That's Unpossible
_____________________________________
Old 03-15-2011, 06:11 PM
nst7 nst7 is offline
Default Re: ExpressCard Firewire, recommendations
Protools does not support any type of RAID in the system.
Old 03-15-2011, 08:35 PM
Eric Seaberg's Avatar
Eric Seaberg Eric Seaberg is offline
I've been using ExpressCards (PCMCIA on Powerbook G4) for many years. I even have a PCI FW card for my G5. There's nothing like keeping everything happy by putting it on separate busses. I have the same era MBPro with a SIIG ExpressCard... actually two of them... one with 2-FW400 and another with 1-FW800.
That being said, ProTools won't like a software RAID, as is created by Apple's Disk Utility, but I have a hardware RAID that does work. Other World Computing sells quite a few of these where you put in multiple drives and configure it how you want to run. ProTools sees it as one drive.
Eric Seaberg • San Diego, CA
A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S.
Old 03-15-2011, 09:32 PM
HD2 HD2 is offline
Agreed, I have an older G4 laptop with the PCI FW card and it works well. Same with the Hardware Raids. I've been using G-Raid drives for years without issues.
Old 03-17-2011, 04:18 AM
thanks for the response.
I wasnt thinking about RAid system of any kond actually.
I want to keep my audio interface on MBP's FW and an external disk on a different hub.
I use GRAid's Mini 320 GB with 7200RPM.
Simple and effective.
So any of the SIIG FW expresscards, will do?
Old 03-17-2011, 02:47 PM
Here is a good selection:
http://eshop.macsales.com/shop/firew...i-pcmcia-cards
I've got this one:
http://eshop.macsales.com/item/SIIG/NN000042S1/
as well as the FW400 version of the same thing.
Old 03-17-2011, 03:20 PM
LanceK LanceK is offline
I use ESATA drives through my express card as well as I just got a MADI card. All works great!
Old 03-18-2011, 07:21 AM
tribedescribe tribedescribe is offline
I use a sonnet express card and it works flawlessly with my 08 macbook pro 2.5ghz. I believe digi has a approved express card also. Mine has two 400 ports and one 800 port. I was plagued with errors because of daisy chaining. This solved my problems.
Old 05-18-2011, 09:25 PM
howlco howlco is offline
I use the Sonnet firewire 800 pro express card 34 .. works great ...
Protools 9.02 - 002 digirack - mbp quadcore i7 - 27 i7 iMac
Old 05-19-2011, 09:24 AM
WinTaper WinTaper is offline
I have a 2009 MBP with the ExpressCard slot. Live setup as follows ...
I use an ADS Pyro 1394a ExpressCard (genuine TI chipset) to go to my Presonus Firestudio Lightpipe interface (FW400).
I use the built-in FW800 port to goto external drives if necessary
-Dan
Pro Tools 2020 | Mac OSX 10.15.x
RME Ray-DAT | SSL Alpha-Link AX
2019 Apple Mac Pro 16 core / 96GB
mbox2 pro and firewire expresscard jameaze 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-31-2010 11:43 PM
Impossible to find SIIG FireWire 2-Port ExpressCard FireWire adapter Bloody Maker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 02-22-2010 09:58 AM
Digi Rack 002 Firewire expresscard? moonblind 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-20-2009 09:47 AM
MacBook Pro and Firewire Expresscard/34 Gunnell Pro Tools M-Powered (Mac) 10 08-22-2007 03:02 PM
Firewire: Internal vs PCIe vs ExpressCard? nikki-k 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-18-2007 05:30 PM
