Old 01-11-2006, 01:15 PM
dwman dwman is offline
Default Replacing Drum Sounds
Hey folks,
I know there has been a lot of discussion about this , but is there an easier way to replace drums that are individually tracked with better drum samples that does not require going from transient to transient to replace them? Is there a way to trigger a drum sample from sampltank or resaon in order to accomplish this task?
Old 01-11-2006, 03:52 PM
The Dougfather The Dougfather is offline
Default Re: Replacing Drum Sounds
I'm afraid not, i went as far as emailing a Pro Tools book author about this and this was the way he advised. In LE this is the only way to do it unless you want to pay for digi sound replacer or drumagog. One thing that will make it slightly quicker if you are not all ready doing it is to mute the track using the command m function, this greys the track out so you can still tab the transients and also paste over the original wave without everything going mad.
Regards
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Old 01-11-2006, 06:23 PM
To trigger samples from Reason or other programs, you would need a trigger-midi interface. Alesis DM4, DM5. Any Roland or Yamaha drum module or the old Roland PM-16. Send audio from the track to a trigger input and assing the right midi note. You would also need to advance the new track to line up with the original(due to latency) but ut would be pretty simple compared to the rest of this technique. Kinda makes SoundReplacer a bargain.
Old 01-11-2006, 06:24 PM
To trigger samples from Reason or other programs, you would need a trigger-midi interface. Alesis DM4, DM5. Any Roland or Yamaha drum module or the old Roland PM-16. Send audio from the track to a trigger input and assing the right midi note. You would also need to advance the new track to line up with the original(due to latency) but ut would be pretty simple compared to the rest of this technique. Kinda makes SoundReplacer a bargain. What about renting the plugin from the DigiStore?
Replacing MIDI sounds with samples or live drum kit bryced87 Tips & Tricks 2 12-14-2013 08:28 PM
Loading in Drum Sounds & replacing oncepureband Tips & Tricks 4 05-17-2011 09:49 AM
Replacing Click Track sounds bakedbeansrecord Tips & Tricks 8 03-24-2007 02:28 PM
Apulsoft apTrigga2 for replacing drum sounds MDog Pro Tools TDM Systems (Win) 0 03-20-2005 06:15 PM
replacing sounds on drumkit - help! Paul_Wolf 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-23-2002 11:52 AM
