Old 02-15-2017, 07:17 PM
Thenewexhibit Thenewexhibit is offline
Default Select multiple clips
Hello,
Is there a way to select multiple random (my choice) clips at once? I know I can hold down shift and then select one clip, then move to the next, click, and have it be selected as well, but, I'm trying to select just the ones I want.
For example, on one track, I have 5 clips... I want to be able to select clip 1, 3 and 5 simultaneously, use audiosuite on just those (1,3, and 5) simultaneously, and not have it render a full clip from 1 to 5. I hope that made sense.
Thanks!
Old 02-15-2017, 11:29 PM
PMF Media PMF Media is offline
Default Re: Select multiple clips
You can certainly use the 3rd option in the grabber tool "Object" and it will allow you to select non-sequential clips at the same time, but applying an Audiosuite plug will effect everything including the non-select clips in between.
Old 02-16-2017, 04:40 AM
joachim's Avatar
joachim joachim is offline
Originally Posted by PMF Media View Post
...but applying an Audiosuite plug will effect everything including the non-select clips in between.
Does not happen on PT11.3.1 with Audiosuite plugin set to "create individual files" and "clip by clip". It leaves clip 2 and 4 unprocessed.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 02-16-2017, 04:30 PM
Awesome! Thanks for your help everyone!
Quickly select all adjacent clips? Cactus T-Shirt Pro Tools 12 2 04-23-2016 11:08 AM
Select multiple Clips with CMD key not working ptr22 Pro Tools 11 13 11-12-2015 02:39 PM
Select Multiple in Bin. Select Multiple In Timeline??? jonathon_l Post - Surround - Video 9 04-30-2012 09:48 AM
Select Multiple in Bin. Select Multiple In Timeline??? jonathon_l macOS 0 04-29-2012 02:39 PM
PT10 (HD?) BUG: Select Unused Clips Bassturbator Pro Tools 10 2 12-24-2011 11:52 PM
