Old 07-17-2015, 03:08 PM
rsandifer rsandifer is offline
Default Using digital Input on HD i/o
Good day my fine duc friends
I have a feeling my search attempts came up empty even though the answer to my question came up several times
I would like to go out of my mac mini using a toslink cable and send it to my HDX converter to hopefully get my jams pumpin. I gave it a shot but after a minute I gave up...not really. So am I missing something on getting the audio into the converter and back out again? As far as that goes I don't even see the digital inputs anywhere in protools. I realize avid makes things so easy that a 4 year old should be able to fix this but I'm stumped
Any help would be greatly appreciated.
Bob Sandifer
Industry Recording Company - Griffin Georgia
404.783.9103 / bob@bobsandifer.com
Old 07-17-2015, 03:48 PM
Drew Mazurek's Avatar
Default Re: Using digital Input on HD i/o
I do this at my studio Bob. It's easy.
You just need to designate a pair of inputs in the Hardware Setup page (or I/O) as Optical (S/PDIF)[ENCL]. The ENCL stands for Enclosure, as in the digital I/O that's past of the unit itself and not any of the cards.
Should look like this.
www.drewmazurek.com
Old 07-17-2015, 04:37 PM
Good advice^^^ My solution; I use a Presonus central Station as my monitor/source controller and feed the optical SPDIF from my computer to one of the digital inputs on the SC. Works perfectly(and is only one of several niceties from the box)
Old 07-17-2015, 05:50 PM
thank you so much drew. So not that I can see everything how do I get....well...itunes to play though my system or do I need to open up a blank session and route it through that
Bob Sandifer
Old 07-18-2015, 06:18 AM
Yes, you do need to a session open for this to work. Not ideal, but you get used to it.
Make an Aux Track and assign its input to the pair you set to optical and its output to your monitor output.
Ot you could find a solution like the one Dave mentioned. I used to have a CS years ago before I got the ICON and it worked very well.
www.drewmazurek.com
Old 07-19-2015, 04:05 PM
Drew this worked perfectly. I just made a session with nothing but a fader showing. I really don't even notice the extra step. Thank you for the help
Bob
Bob Sandifer
Is there a way to use a digital input at 96k from a digital output at 48k? rockguitarist1255 Pro Tools 10 3 01-04-2012 06:48 PM
8 tracks of digital input at 96k possible? cprescott1972 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 02-04-2008 08:23 AM
Problems When Using the Digital Input dmanley123 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-02-2004 04:44 PM
888's and digital input MitoPro Pro Tools TDM Systems (Mac) 1 03-12-2004 05:02 PM
Digital Output from 888/16 isn't compatible with Digital Input of TC M2000 & PCM 80 beerbr Pro Tools TDM Systems (Mac) 0 11-02-2000 09:01 PM
