Phase alignment using different paths to record?
I'd like to tap the braintrust here on something regarding a specific recording scenario. (paging Propower and Rich Breen)
Has anyone tested the time alignment of a signal that travels from an Avid HD I/O or an Apogee Symphony box directly into PT vs. a signal that goes into a Presonus Digimax LT and gets into PT via a lighpipe connection? Im trying to figure out if I can replace a Sytek 4 channel pre (that I rarely use--basically overflow pres) with a Presonus box that I also have. Just trying to simplify my setup and conserve A/D. |
Re: Phase alignment using different paths to record?
best, rich
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
Of course Rich!! So simple. Will try that tomorrow.
2017 27" iMac 3.8GHz i5, 1TB SSD Logic ProX, Studio One V4, PT current version, Apogee Ensemble TB Musician: http://www.ivanlee.net/ Design Engineer: http://www.propowerinc.com/resume.html |
Presonus through an ADAT input is 36 samples later than Avid HD I/O. The pic shows a square wave, but I used a few different sound sources.
That's what Time Adjuster is for, though unless multiple mics on a single instrument/ensemble are being split across interface types (generally a bad idea), the 36 samples *may* not matter to Drew.
Little bit older thread, but I just did some testing (and solutions) for this with various scenarios.
I'm not certain the DLA plugin is available in Native like it is in TDM, since I track exclusively in TDM. Solution: Measure delay for converter. Insert DLA plugin on the the fastest converters (Apogee or HD I/O) Set it to the number of samples difference you measured Turn OFF compensate for converter delay on input. Use the ADC bar in the mixer view and insert the delay plus 3 samples (TDM delay) as a negative on the other converters. The reason we do that as well is so you hear both recording and playback in phase. Otherwise, playback would be in phase, but not recording/monitoring or vice versa. I figured this out recording drums and noticing the variation in phase when using my HD I/O with a 192 (symphony is on the fritz...). This works perfectly. The simpler solutions will play back fine, but you'll hear phasing/comb filtering if you're splitting across converters as you monitor. Same thing if you leave the compensate for recording delay box checked. Hopefully this helps others. You can even mult/parallel without comb filtering across various converters. BTW, 192 is 48 samples later than HD I/O. Mackie Onyx was 6 (4 connected to the 192 instead). Apollo was 73, IIRC. |
alignment and phase for multiple kicks | Macsearcher | Tips & Tricks | 4 | 11-19-2013 08:48 AM |
Grid alignment | Mark Ziebarth | Pro Tools TDM Systems (Mac) | 12 | 11-02-2009 12:40 PM |
Question about Sub Paths and Main paths. | oulablank | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-15-2009 12:15 PM |
phase cancellation in record mode | wship | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-29-2007 01:55 PM |
96I/O alignment | ndlsd | Pro Tools TDM Systems (Mac) | 2 | 10-12-2005 05:07 AM |
