Old 11-20-2013, 09:23 AM
madmarkdj madmarkdj is offline
Default MIDI clips/regions copy/loops
Hi all
I am a long time Logic user (since version 4) and just moving over to Pro Tools.
Now I have the following "problem":
I have recorded a 4 bar MIDI sequence which I loop for let's say totally 16 bars. Now, in Logic I did this with the loop function or by using aliases. In Pro Tools I have found the loop clip function. So far so good.
But, if I now want to edit some notes of that 4 bar sequence PT breaks apart the "loop" in two pieces. First 4 bars with my edited notes and remaining part without the edits. In Logic it is so easy to just do the MIDI edits on the "Original" region and every alias (which is kind of a clone without data) will automatically play with the edits.
Is there any way to do this in Pro Tools without having to do the looping again after editing?
Thanks in advance!
Old 11-20-2013, 09:37 AM
Shan's Avatar
Shan Shan is offline
Default Re: MIDI clips/regions copy/loops
Enable Mirrored MIDI Editing:
Options > Mirror MIDI Editing
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 11-20-2013, 09:50 AM
Thanks for your quick answer, Shane!
Old 11-20-2013, 10:31 AM
soybalm soybalm is offline
Another plus for Pro Tools "awful" midi implementation. I haven't tried this feature in PT since PT 9. I'm amazed how it works when you break a loop. It automatically continues your previous loop. Someone must have known that it was a pain in Logic to turn loops into real copies, then have to re loop. You can also edit from bar 30 if your loop in bar one is mirrored. I think Logic could do that with Aliases but once again, a better workflow in PT. Now if they could fix some timing issues and more notation features like LYRICS.......;-) maybe a flexible key command set for the midi window.
Dave Cournoyer-guitarist-project studio
Mac Mini late 2012, i7, Sierra
16GB PT10.3.10HD PT12.5.2
Apogee Mini-Me firewire.
Old 10-11-2019, 07:43 AM
Firechild Firechild is offline
Great tip!
iMac Pro - HDX2 - Mojave - AVID HD I/O x7
Old 09-08-2021, 10:33 PM
bluskiff bluskiff is offline
select the midi loop and consolidate it. Edit/consolidate
Turns it into a real copy.
best way to copy and allocate clips on new harddisks Mubeau Post - Surround - Video 5 02-20-2014 11:09 AM
Can´t copy MIDI regions properly... Firechild Pro Tools TDM Systems (Mac) 2 11-25-2012 04:27 AM
Copy multiple clips? georgepeter macOS 6 03-07-2012 10:02 AM
Drag and copy clips superproducer Pro Tools TDM Systems (Win) 5 01-08-2006 04:56 PM
how do I copy midi regions based on beats CyanJaguar Digidesign Hardware & Software 1 03-28-2001 01:08 AM
