  #181
Old 06-15-2015, 04:47 PM
8dB.co.uk 8dB.co.uk is offline
Default Re: Video Engine Problems with Pro Tools 11
Yeah, been fixed (not that it was particularly broken) since at least 11.2.1. The video engine in 11 bears no resemblance to 10. On a PC (Windows) it also allows you to use third party video output devices, such as Blackmagic, to output proper genlocked video output.
Pro Tools Utimate 2018.7, on -
i7 5820k 6 x 4GHz (12 threads), 16GB DDR4, Win 10 Pro, BM Mini Monitor PCIe, GTX 660Ti 2GB;
Dell Laptop, i7 4x3.6GHz (8 threads ), 16GB DDR4, Win 10 Pro, GTX1060MaxQ 6GB;
"Plan B" - i7 6700k, 4 x 3.4GHz, 16GB DDR4, Sierra, AJA Kona LHi, GTX 1050Ti 4GB.
RME FireFace802 + ARC, RME Babyface
Avid D-Command, Artist Control, V-Control, Korg MicroKontrol
7.1.2 Presonus Monitors
  #182
Old 06-16-2015, 01:20 AM
thomasrichard thomasrichard is offline
hmm I use 11.3.1 version and just get a white video window (DNxHD) workz in 10..?
/ T
  #183
Old 06-16-2015, 03:57 PM
lancemcv lancemcv is offline
I have two boot drives one is MT Lion and PT 10 and video playback has never been an issue. The other drive has PT 11.3.1 and 10.10.3. Video playback starts off fine and then after a few moments it gets all choppy playing the same session that was fine with PT 10 and MT Lion.
I tried putting the video on a separate drive and it made no diff.
Anyone with the same issue? I have tried H264 and Pro Res 422, no diff.
I finally got all my plugins working in PT 11 and now this is happening so I still can't use PT11 and 10.10.3 for work when video is involved.
I really don't want to buy PT 12 to find 600 bucks later it still has the issue.
I have a R9 280X video card which works great with everything but video in Pro Tools 11 when in Yosemite.
Does anyone have normal video playback in PT 11.3.1 and 10.10.3?
I guess some folks are not even getting video to playback at all....
  #184
Old 06-16-2015, 07:32 PM
Wizzoboy's Avatar
Wizzoboy Wizzoboy is offline
Like 8db, I have not had any problems running video in PT 11.3.1. But I am running PT under Win 7 on a PC, not a Mac.
Dell Precision 490 Workstation, dual 4 core 5355 Xeon, 16gb Samsung DDR2 ECC Ram - Windows 7 Ultimate - Nvidia GTX 650 - 3 x Internal WD Blacks - PT 2018.3 - Digi 002R - Original Mackie HUI - JBL Monitoring.
Dell XPS 8700 i7-4790 - 24gb RAM - Windows 10 - Nvidia GTX 1060 6GB with Studio driver 431.86- 2 x Internal WD Blacks + MSATA card - Davinci Resolve 16.1 - Canon HF G40
  #185
Old 07-09-2015, 02:02 AM
kava kava is offline
same problems still appear in pt 12.
till today i haven't been able to play a single 90min movie file without problems after 10-15min. i really tried every fix i could find...
any news?
2xMac Pro 2014 6-Core, 48GB Ram, OS X 10.12
ProTools HD12 and Ultimate, 2x HDX
NTP Penta720 I/O + 192 HD I/O + SSL Madi Link
Sync HD, Dolby Atmos RMU
S6 - M40 - 32channel.
Filmpost at cosmix studios vienna
http://www.cosmix.at
http://www.tom-kava.com
  #186
Old 07-09-2015, 07:26 AM
Ray JB Ray JB is offline
After several weeks of no problems on pt12 I've had several days of "waiting for video operation to complete" messages and the consequent system lockup that occurs, much like problems I had in early versions of pt11. Pictures play off a dedicated Samsung 850evo 512gb drive internal to my Mac Pro 5,1. Mac OS X 10.8.5. Black magic driver is at last 10.8.5 supported version. Avid DNx36 pics.
This needs to work.
  #187
Old 07-24-2015, 08:00 AM
AudioEngineer591 AudioEngineer591 is offline
Install Windows 10 for better Video performance!
AVID Pro Tools 12.2
Windows 10 Pro
Intel i7-4800MQ @3.7GHz
GTX870M 3GB
32GB DDR3L-1600
  #188
Old 07-24-2015, 06:34 PM
The Weed's Avatar
The Weed The Weed is offline
Any idea if AVB (Audio/Video Bridge) is in Windows 10?
Thanks,
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
  #189
Old 08-30-2015, 10:37 AM
Nige7 Nige7 is offline
Originally Posted by mrhood View Post
Hi
First post here, hope you guys can help!
I get this error when trying to enable the video engine in Playback Engine (Pro Tools 11 Vanilla). It loads a progress bar and a message: "Waiting for the Video Engine to launch" and does nothing when it completes and I then need to hit cancel to continue using PT. Everything else in PT works fine.
I've tried this with PT 11.0.0 on a Mac Pro 2008 8 Core as well as an i7 Hackintosh (both on 10.8.4) with the same problems. Re-installed PT with no luck. Next option is to download 11.01 update.
I've searched the Avid forums and all I could find was an error with Media Composer been installed with PT 11 where the AMA Plugins needed to be deleted and then the error was resolved, but I do not have MC, so I'm stumped.
Any ideas ?
EDIT: So now 1 year on and no change whatsoever. Tried all the updates from Avid and suggestions from other users to "trick" PT 11 into loading the video engine. Nada... PT 10 is still fine.
This is my last Pro Tools purchase.
Thanks all for your help, but I won't be participating here anymore.
Cheers
Robin
Hi, I am stuck with video editing, I have got video and music both in the edit window but not able to move video in timeline so I can continue to write / structure music around as ref etc. Please help or any guidance, thank you.
  #190
Old 08-30-2015, 12:15 PM
The Weed's Avatar
Use Spot mode to move the video.
Cheers,
Pro Tools 10 Video Engine failed to initialize. GXTProductions Pro Tools 10 1 12-15-2013 01:54 PM
Boot Screen "Not Recognized Video Hardware Connected", "video engine failed to init bcrichguitar macOS 3 04-01-2012 10:10 AM
Pro Tools HD 8.01 Launching Video Engine fails? AMIEL Pro Tools TDM Systems (Mac) 3 10-25-2009 12:38 PM
Pro Tools 8 LE stalls at video engine launch Tommy Barth 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-13-2009 02:44 PM
Where's the Video Engine? admix Post - Surround - Video 4 05-02-2008 05:51 PM
