Old 01-02-2005, 12:09 PM
Fladlien Fladlien is offline
Default How to reduce white noise/static?
I am running a turntable into my pro tools but for some reason the level is really low so I have to turn the input knob almost to full. By doing this I am getting a lot of static when I record the table to pro tools. What I am curious about is twofold:
1) What is the best way to record turntables into pro tools?
2)What are some techniques (such as eq'ing etc.) to reduce static/white noise on an audio file?
Thank you for reading this.
Old 01-02-2005, 02:33 PM
LeGato LeGato is offline
Default Re: How to reduce white noise/static?
Try running your tables into your mixer (pioneer, vestax.etc.) and adjust your volume through the mixer into your mic pre's.
White noise is probably impossible to eliminate, I would say delete or mute the file and you'll have no white noise. Static and clicking can be drawn out with the pencil tool.
Hope this helps you,
RS
Old 01-02-2005, 02:36 PM
A turntable requires an RIAA phono preamp.. you can't simply plug it into your mic preamps -- you'll get high noise (as you've dicovered) and the EQ curve will be wrong and it'll sound wrong.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 01-02-2005, 02:46 PM
yOkO yOkO is offline
what LeCat mean is that you need to preamplifie
your turntable, any stereo preamp will do, if your stereo system
have a preamp out, it would do the work.
cheers.
look at rails coment about riaa preamp,
i was posting at the same time.
so what
Old 01-02-2005, 05:28 PM
41217 41217 is offline
Rail
This IS completly true!!But u dont need an RIAA phono preamp!Beside the RCA i/p connectors is a screw, which is the Earth for ur Deck to hook on too!!
static white noise Rawer macOS 15 03-31-2013 02:16 PM
How to reduce static noise from guitar? Thing Eleven Rack 17 03-12-2012 05:16 AM
static white noise solution craigyj Pro Tools SE and Essential (Win) 2 02-21-2011 01:06 PM
Static noise (aka White noise ) During playback. =/ PoPimp3069 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 03-23-2010 05:06 PM
Static/White Noise Neodustin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-06-2006 05:21 PM
