Old 12-01-2004, 05:11 PM
thevessels thevessels is offline
Default optimizing your mac...?
ok what are some tips to get the most out of your mac when using pro tools
should u make a new account and disable everything ?
what are some guidlines or anything to help your machine all around run smoother
thanks
-chris
Old 12-02-2004, 09:24 AM
TrickyDyk TrickyDyk is offline
Default Re: optimizing your mac...?
More more more more more more and more memory! Get as much as you can fit in your machine. I would also suggest doing a google search for OS X performance tips. There is some valuble info floating around the web.
Old 12-02-2004, 10:00 AM
Installing more memory than is needed will yield no performance benefit.
Learn how memory is used, and learn how to interpret Activity Monitor.
Quad 2.5 G5, 4.5G RAM
Old 12-02-2004, 10:38 AM
41217 41217 is offline
Tele's right!Theres a cap on the amount of memory used for ProTools!
If you wan to optimise your mac for PT, then just follow the guidelines that go with the installation!
Dont use your mac for anything else also helps,no games,no NET!
Old 12-02-2004, 12:20 PM
I also disagree on the 'don't use the Mac for anything else', though for most people, that's probably the simplest solution.
Old 12-03-2004, 12:14 AM
JFreak's Avatar
JFreak JFreak is online now
simplest solution for being able to use the computer for everything and still have good protools performance is to have a dedicated protools user in the system and not use that account for anything else but protools and other audio apps. it is true that normal use of a system will clutter it over time, so keeping things tidy for protools cannot hurt
Janne
Optimizing for 8.0 Andy Gerome 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 01-13-2009 08:04 AM
Optimizing PT 5.1 for G4 Sonicvalley Pro Tools TDM Systems (Mac) 0 03-12-2004 03:14 AM
Optimizing OS X 10.3.2 for PT 6.2.2 LE p_frog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-01-2004 07:44 AM
Optimizing XP Pro - Help Please! wizard333 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-30-2003 11:55 AM
Optimizing.... SoundAdvice Pro Tools TDM Systems (Mac) 4 07-06-2000 12:05 PM
