Parallel FX - Send vs audio output path
Greetings. I feel like a complete noob (as always) at the discovery of the fact that you can select multiple simultaneous outputs from the Audio output path selector. Until now I've always just used sends to create parallel FX buses.
Coming from a different DAW a few years ago it never even occurred to me that this was even an option. Apart from having a fader on the insert, I can't see much difference. One benefit I can see using sends, apart from that's what I'm used to, is that if you have a send it is much easier to see as opposed to the little plus sign next to the audio output path. What am I missing? Is there a benefit for either method? |
Re: Parallel FX - Send vs audio output path
I always use sends here. As you said, its easier to keep track of it all.(and its a holdover from the old days of analog consoles).
Thanks Albee. I was reading something and they used multiple audio out in their example. I though it was weird as I'd never seen it done this way so I looked it up and saw another example. That's when I had that moment where you think have been doing this wrong all this time (I have that moment a lot).
I've heard some say they use this to set their Submix aux track's output to both the master output, as well as a stereo audio track for printing the mix inside Pro Tools. When you're ready to print, you just record arm the muted audio track while still monitoring through the MF. I just change the output of the Submix track when I do this though.
It just gives you another way of connecting the dots. You could also name a bus "drums", then use the same bus as input to two separate processing paths. Still feeding two different places, just another method.
I usually use the send option for the ability to have the send level be different than the "output" level.
HD Studio, PT2022.6, UA Apollo x6, 2018 MacBook Pro, 32 Gig, Big Sur |
I predominantly use sends for sub-mixes and stems and/or FX channels. I save window configurations to have all the appropriate sends lined up as if it were a separate mixer. A mix within a mix as it were, as mentioned using audio tracks to record to or Aux tracks for plugins/routing junction.
Sometimes I'll leave the channel output to Main bus as well as a send, and other times either or.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
having a discreet level and pan adjustment is one.. the other is sends can be muted when you don't want you track outputs muted or vica versa.
If your on HD, the copy to send function is great to set initial levels. But it is cool that PT offers a lot of options to get to the same result, just depends on your workflow. ff |
Mic/Line 1 and Output 1-2 not showing up in audio input path selector | gelianamrie | Windows | 4 | 08-02-2012 04:29 PM |
Re-setting output path | irvind | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-29-2009 03:31 PM |
What is a good output path? | mij sang | Tips & Tricks | 12 | 01-20-2009 06:02 AM |
copy a send (w/send level intact) from 1 to 30 audio tracks? | MixerGuy | Pro Tools TDM Systems (Mac) | 3 | 12-30-2007 03:20 PM |
5.1 output path not available? | 316 | Post - Surround - Video | 2 | 12-06-2007 11:52 AM |
