#21
Re: 2021.3 constant hangs
I recorded a 5 minute track on 128, then again on 64 and no hangs.
5K Retina 27" (2020) iMac OS 13.6.5 Ventura 3.3 GHz 6-Core intel Core i5 AMD Radeon Pro 5300 4 GB 64 GB 2667 MHz DDR 4 Internal 2TiB SSD Pro Tools 2024.3 EuCon 4.8.6.41 / 2023.11 UA Luna UAD 11 UA Apollo Twin X Avid S1 / Fire10 - 21.8.1.0 PreSonus DigiMax FS 8-input ADAT Dynaudio Monitors PreSonus Temblor 10 Sub Check my Music out here: Paul G YouTube Paul G Bandcamp |
#22
well i am narrowing it down more ... if i go to 32 samples which is cool i won't have any hangs unless i record arm any audio track ....
System Details: iMac Pro 2017 8 Core Intel Xeon 3.2 Ghz Macbook M2 Pro macOS 14.4.1 Pro Tools 2024.3.1 Logic Pro X Reason 12 UA Apollo 8p Apogee Thunderbridge/Apogee Symphony I/O 2x6 Eleven Rack/Focusrite ISA Two/Onyx 1640i UAD Satellite Quad MOOG Mother 32 Nektar Panorama P1 Axiom AIR 49/Axiom 49/Yamaha P35 Fender Mustang/Marshall Amp/Ibanez Pedals/Fender Strat/Yamaha FG820L/Martin DJr10e Genelec 8040b/Yamaha HS80s/M-Audio BX5a Beats Solo/Shure SRH1840/Slate VMS https://open.spotify.com/artist/7KfV..._branch=1&nd=1 |
#23
Anyone has similar issues ?
#24
#25
Becharax this is an issue I've been dealing with since switching to my Apollo X8 a year and a half ago. Arming tracks will cause system hangs at 64 samples and below.
#26
Self made problems guys. I very seldom have a reason to go below 128 buffer (@48k) which is/was the default playback buffer on HD systems. It is also typical latency of digital mixing boards used on stage. If that latency would be a problem, there would not be any live gigs mixed or monitored on digital consoles.
I even have great success using 256 buffer if needed. I have tested these latencies extensively for two decades already. 512 will be unusable for anyone, 256 is usable for most. Though with modern systems it beats me why end user could just not have a slider of how many samples is needed. I would probably set it to 350 which is a real world DSP latency of typical full TDM mix, only TDM plugins included. And those ancient TDM systems were praised "fast".
#27
offthewallproductions Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4 Pro Tools Ultimate 2024.3.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface. Genelec 1031AP/7070A 5.1 monitoring. |
#28
Well I never complained about 128 :) It runs smoothly for me and even with vocal tracking, Guitar Tracking I am absolutely fine ... it just beats me as to the point where I can go lower to 32 samples on Logic without a glitch and not being able to do so on Pro Tools no more no less :)
#29
No freeze issue here, but some graphical glitch.
Inviato dal mio iPhone utilizzando Tapatalk |
#30
I have rolled back to 2020.12 and again can track at 64 samples, 24/48 session. Recorded about 8 hours over the last two days, no hangs or freezes on 2020.12. (Also, 2020.11, 2020.5, 2020.3 worked well with these settings... It's worked well enough in the past that I'd "set it and forget it" when tracking, so latency just was never an issue.) Literally nothing else has changed about my system. This indicates that something in 2021.3 has broken in comparison to 2020.12.
* Macbook Air : M1 ~ 16gb ~ 1tb ~ Ventura latest * Hackintosh : i9-9900k ~ 16gb ~ 3tb ~ Monterey 12.6.1 * PT 23.6 + Ableton Suite 11.3 * Soundtoys + Valhalla + Fabfilter + Spitfire * RME Fireface UCX II ~ Arturia Keylab Essential 49 * various clarinets, trumpets, flutes, plucky stringy thingies Last edited by huzzam; 04-01-2021 at 11:15 AM. |
Any benefit to TDM in 2021? | akopp | Pro Tools TDM Systems (Mac) | 41 | 01-12-2022 11:05 AM |
PT 2021... Catalina? Or Big Sur? | Eric Lambert | Pro Tools | 3 | 03-26-2021 12:41 PM |
Come on! 2021 already. Just issue what’s right. | DetroitT | Pro Tools 2020 | 0 | 03-05-2021 05:35 PM |
