Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
Old 05-07-2014, 12:29 PM
HKnight HKnight is offline
Default Mbox 3 Pro Drivers 1.1.10 and Windows 8.1
For some reason, none of the drivers after the original drivers that came with my Mbox 3 Pro have EVER worked correctly. They might work for a day or two and then I run into problems. (Versions 1.1.8, 1.1.9, etc...) If I uninstall and install the 1.0.19 drivers...everything works perfect. NO HICCUPS! Is there something I am doing wrong or does something in Windows 8.1 have to be configured differently to have the latest drivers work properly?!?
Any suggestions would be kindly appreciated.
Thank you
Howard
Corsair 800D Case w/750w corsair psu
Asus P6X58D-E
Intel Pentium I7 - 930
NVidia GTX 650 2GB DDR5
12GB OCZ DDR3 Ram
1 - 128gb Samsung SSD
3 - 2TB Seagate 7200rpm harddrives
Phillips Bluray 12x burner
Mbox 3 Pro w/ProTools 10.3.9
Windows 8.1 64Bit Pro
Old 05-07-2014, 01:03 PM
mesaone mesaone is offline
Default Re: Mbox 3 Pro Drivers 1.1.10 and Windows 8.1
What firmware is your MBOX 3 Pro using?
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
Old 05-09-2014, 01:49 PM
1.04
Asus P6X58D-E
12GB OCZ DDR3 Ram
Old 05-09-2014, 02:04 PM
And you tried the 1.1.10 driver that came out 9 days ago?
http://avid.force.com/pkb/articles/d...ox-Pro-Drivers
Old 05-28-2014, 11:33 AM
I did and it was still the same problem for me.
Asus P6X58D-E
12GB OCZ DDR3 Ram
Old 06-04-2014, 08:37 AM
There is a significant change between the official drivers released with my mbox and the newest ones that does not allow Windows to recognize my audio interface all the time. I have absolutely NO problems with the ODs.
Asus P6X58D-E
12GB OCZ DDR3 Ram
Old 06-12-2014, 03:31 PM
Emcha_audio's Avatar
Emcha_audio Emcha_audio is offline
Do you by any chance start Windows without having the Mbox powered on? If so, Windows will revert to an other set of "speakers". If you have set the Mbox as the default audio device in Windows (start -> Control Panel -> Sound -> Playback tab) you will see a green check mark beside the mbox. if you don't see it beside it, then it's not the default audio device and this is probably why you are having problems.
Manny.
Wave-T.com
Old 07-12-2017, 09:03 AM
Windows 10 and MBP Drivers 1.1.10....this problem still persists. I cant properly use the new drivers with my computer even updated to the latest Windows, all devices with the latest drivers. ( Let me restate my complaint, the drivers work only when I restart the mbox, the original drivers that came with the device do not require any restart of the mbox in order for it to work) Could it possibly be my firewire port? The latest drivers are in place for it and the original drivers give no hiccups. I would love to resolve this as the newer drivers appear to have a few more options than the original.
Please Avid, you're my only hope ***inserts a random Death Star bluprint card into R2D2***
Thank you kindly
HKnight
Asus P6X58D-E
12GB OCZ DDR3 Ram
Old 11-09-2017, 07:35 AM
Ok, its 2017...Ive been using an older driver but I havent done much recording in a while, just mixing. I went to record and my buffer size wasnt able to change from 256. I installed the 1.1.10 drivers again and it works BUT now I am back to a card that isnt recognized by windows half the time and now creates the BSOD. Is it possible that Avid simply makes a driver that is STABLE for Windows 10 (1709) and MBox 3 Pro?!? Come on Avid, I truly dont think my request is unreasonable. A new one hasnt been released in almost 3 years. I know the product is discontinued but I pay money annually for support so they finances are there to create a stable once and for all driver. If someone on here has a suitable solution I am game for what you have.
Asus P6X58D-E
12GB OCZ DDR3 Ram
Mbox 3 Windows 7 64 bit drivers roberts 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-10-2012 01:46 PM
Where do I find Mbox 2 drivers Windows 7? Samba 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-12-2011 10:59 AM
Mbox 2 mini drivers for Windows 7? ajd315 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-09-2010 03:37 PM
MBox Windows 7 Drivers ssvmakis General Discussion 0 03-07-2010 07:29 AM
Ok Digi, I now need Windows Mbox drivers Nitronick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 11-19-2002 11:46 AM
