Export issues
Hello,
I am using a mac mini, late 2012 with 8GB of ram, hard drive lacie quadra 1TB. No sound card so using the build out one. Was working on a session the other night, with the amount of treatment on each tracks, the cpu was overloaded. I have tried to bounce every busses( Inst/Lead Voc/BG Voc/Drums). Doing that, Going on another session to pre master, no way to sync the tracks correctly as there was a delay, and not the same on each tracks, is it possible that the issue comes from the fact that I am using no sound card? |
Re: Export issues
Try Spotting the files in the new session (Spot mode, Grabber tool) If you didn't bounce from the same time for each, this will put them where they belong. Did you have delay compensation on in the original session? Playback engine shouldn't have anything to do with this. |
Re: Export issues
I belive i did cause I actually leave the delay compensation on every session
Re: Export issues
would it be any better for me to add more memory and Crucial SSD to the mac mini to avoid cpu overloading???
Like Russ said here???? http://www.pro-tools-expert.com/home...th-a-look.html |
Re: Export issues
impossible to say without knowing your current specs.
Re: Export issues
Re: Export issues
What processor?
Re: Export issues
Re: Export issues
This is the likely bottleneck as opposed to RAM or an SSD, although beefing those up never hurts.
Do you have a friend that has a more powerful computer that you could test a session on? Something with a quad core i7. Would be good to see an improvement before you spend any money. |
Re: Export issues
pro tools export issues | DaveSaia | Post - Surround - Video | 1 | 11-07-2014 11:38 AM |
Strike 1.5 Midi Export Issues | dreamslide720 | Virtual Instruments | 31 | 02-07-2013 01:04 PM |
Track Export issues | Sturphy | macOS | 0 | 12-06-2011 06:36 PM |
.MID export issues | tonejunkee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-05-2008 05:24 PM |
6.2 TDM on XP - MP3 Export issues | Ken P | Pro Tools TDM Systems (Win) | 2 | 06-01-2005 09:32 AM |
