Delay When Committing or Printing
I'm having a problem, that's come up several times over the years, but I've never found a solution for it. I'm trying to commit a track and Pro Tools is causing a delay of around 127 samples to the committed (or printed) track. The screenshot I've attached shows the printed track (on bottom) that's been delayed. It's about the same amount of delay whether I'm printing or committing.
Delay compensation in on, and with only a single instance of FabFilter's Pro-Q 3 on the track, it's obviously still displayed in green (not orange or red). So, according to the delay compensation, committing or printing this should work without causing any delay. Restarting Pro Tools, and then my MacBook Pro, haven't fixed this problem. System info: Pro Tools Studio 2023.12.0 MacBook Pro M1 Max OS - Monterey 12.6.8 I'll also note this this is a very small session, with only 14 tracks and very few plugins, since it's just any editing session for a few sound effects I recorded. Does anyone have any suggestions? Thanks! |
Re: Delay When Committing or Printing
Does it happen with any other plugins? What interface are you using?
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Is ignore errors on? Turn it off.
What is the H/W buffer size? What are the track inputs? from? If you have no inputs to that track turn inputs off and see what happens. What phase mode is Pro Q3 in and what latency is showing up on that track? Can you reproduce this is a trivially simple session and share that whole session? It's also impossible to understand exactly what your screenshot is showing. Remember depending on what mode the plugin is in there can be significant signal shape changing and frequency dependent lags due to the phase behavior of the EQ being properly modelling by the plugin Last edited by Darryl Ramm; 03-03-2024 at 07:59 PM. |
Delay compensation not working when committing?? | Peters86 | Pro Tools 12 | 5 | 02-15-2019 06:57 AM |
Delay when printing/committing tracks | jaydenseeley | macOS | 3 | 05-26-2018 09:15 PM |
Midi Playback Delay when printing | WernerF | Pro Tools 10 | 7 | 02-23-2013 10:05 AM |
delay compensation and printing mixes | James Drake | Pro Tools TDM Systems (Mac) | 4 | 07-26-2011 04:09 AM |
Printing plugin compression + audio: delay???? | Tubthumper | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-30-2005 05:05 PM |
