Old 02-03-2024, 09:21 AM
corym corym is offline
Default Aux IO Output disappears when changing btw HDX and Aggregate
Hi there, curious if anyone has had this experience.
I recently added an HDX system to my workflow in the studio. So now I'm back and forth between the HDX in the studio, and native at my home studio. When I open sessions between the two, the AuxIO output keep disappearing, and there's no option to open it from the session. I have to manually rebuild the outputs, and then manually route my sends on the bus tab. AuxIO Inputs work and stay as expected between the two systems.
I was wondering if there's any solution to solve this issue, or if it's just the way it is?
-Cory
Old 02-03-2024, 02:15 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Aux IO Output disappears when changing btw HDX and Aggregate
Hi, Have you tried Export/Import Settings in the I/O window?
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 02-03-2024, 03:03 PM
Yes, I've tried that in the past. However, that seems like an unnecessary step, since the Input AuxIO is carrying through. There must be a way for the Outputs to carry through as well, no?
-Cory
Value disappears when changing Clip Gain in 2022.9 home_studio Pro Tools 3 09-28-2022 11:37 AM
HD Native randomly disappears from Output Device list. Focuret Pro Tools HDX & HD Native Systems (Mac) 4 03-31-2017 10:21 AM
Pro Tools 9 Aggregate Output Missing Tha Rhythm macOS 3 07-23-2011 01:41 PM
One output channel disappears when adding a track remainanon Pro Tools TDM Systems (Mac) 4 10-06-2008 01:39 PM
Changing output on all tracks? Kurty B Tips & Tricks 1 09-07-2006 07:01 PM
