Old 12-07-2023, 05:23 PM
raw raw is offline
Default Resolved: Avid Link 2023.11 crashing when installing certain Sonic Drop packages
Resolved and this issue has been fixed and the fix will be in our next release
Hi
Avid Link 2023.11 crashes when I try to install certain Sonic Drop packages e.g. Brutal Vegetables. The package downloads, installs files but Avid Link crashes leaving behind the download zip file e.g. Brutal Vegetables_SL.zip. This behaviour has been reproduced on two separate PT systems:
1. Mac Studio, Monterey 12.7, PT Ultimate 2023.9.0
2. MBPro, Ventura 13.5.2, PT Studio 2023.9.0
The crash dump says:
Crashed Thread: 19 ContentDropManager Thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
Exception Codes: 0x0000000000000001, 0x0000000000000000
Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process: exc handler [32395]
Anyone seen this? Thanks.
Rich
Old 12-07-2023, 05:39 PM
Default Re: Avid Link 2023.11 crashing when installing certain Sonic Drop packages
Avid Link crapware living up to it's well deserved reputation.
There must be a reason that Sonic Drop installers are not just provided for easy reliable install and download in Avid.com accounts. ¯\_(ツ)_/¯
Old 12-07-2023, 06:08 PM
cwsand's Avatar
cwsand cwsand is offline
I've never used Avid Link - too many problems.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 12-08-2023, 10:43 AM
nednednerb's Avatar
nednednerb nednednerb is offline
Yes, it happens to me too with new Avid Link 2023.11
It forgot that it downloaded about 3/4 of them, I hit download all again, like you said, it got to Brutal Vegetables ZIP on the drive, then crash.
___
>> me: nednednerB //
||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music //
||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 //
||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock //
||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR
||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts //
Old 12-08-2023, 11:26 AM
MDGenerato's Avatar
MDGenerato MDGenerato is offline
Originally Posted by raw View Post
Hi
Rich
Hi! Can you send me an email at [email protected] with your Avid account email address so I can create a case for you? Thanks!
Old 12-08-2023, 01:28 PM
JingleDjango JingleDjango is offline
I presume there is data they would like to harvest and they can't extricate it from the browser. I don't know why else they want to funnel users through the abomination that is Avid Link.
Old 01-07-2024, 03:51 PM
MarkH MarkH is offline
Was there a solution for this? There's no other way I'm aware of to download the Sonic Drops other than using Avid Link. About half of them fail to install and crash Link.
Old 01-08-2024, 05:30 AM
MDGenerato's Avatar
Our devs are currently checking on this issue. In the meantime, we need to collect some logs from you guys by going to
HD/Users/Library/Logs/Avid/AppManagerUI
Thanks!
MDGenerato's Avatar
Thanks!
Old 01-08-2024, 06:11 AM
Thanks!
Log file uploaded: https://github.com/markholloway/mark...4_09-00-17.txt
In this log file you'll see I was able to successfully install Brutal Vegetables, PurrCell, but when I tried to install Burnin' Breaks is when Avid Link crashed. I renamed .log to .txt so I could push to my public Git repo folder.
After the crash I do see the Zip files downloaded and extracted in /Documents/Pro Tools/Sounds Libraries/ although I'm not sure which ones are just loops and which ones should be installed as PlayCell instruments. I do see PurrCell installed as a PlayCell instrument, not sure about others as they do not seem to have a .playcell preset in the Zip file. Are there more libraries than PurrCell that are supposed to be loaded as PlayCell instruments?
Avid Link/Sonic Drop briaboy Pro Tools 6 11-07-2023 06:42 PM
Avid Link updated... PT 2023.9 on its way? Eric Lambert Pro Tools 21 09-11-2023 05:19 PM
Avid Link 2023.6 Now Available DigiTechSupt Technical Alerts 0 06-07-2023 10:45 AM
