Old 07-22-2014, 02:44 PM
Firechild Firechild is offline
Default Decide MIDI in port per track ?
Is there a way to route a specifik MIDI in port to one instrument track, meaning you can use Pro Tools in a more flexible way when it comes to live MIDI instruments from different MIDI sources? Now you can only choose which MIDI in devices are available in a global setting, not per track?
iMac Pro - HDX2 - Mojave - AVID HD I/O x7
Old 07-22-2014, 04:18 PM
Default Re: Decide MIDI in port per track ?
Once devices and ports are set in Midi Studio, this works fine. I have used 2 keyboards and a Roland V-kit(all at the same time) to "play' MiniGrand, DB-33 and Addictive drums(on 3 stereo instrument tracks) with no cross-talk or issues at all. Midi Studio is where it all gets setup. Then select View>Mix Window Shows>Instruments, which adds a box at the top of any instrument track where you select the device that provides midi to that track/instrument(the plugin instrument)
Old 07-22-2014, 09:59 PM
Ahh, thanks , will try that!
I am not in the studio...but do you have to rec arm the tracks or is it a input monitoring feature for midi too...?
Old 07-23-2014, 09:02 AM
I do have to arm the tracks(hold Alt and arm 1, and all instrument tracks will arm), but I have the default thru instrument(in preferences) set to NONE.
FWIW, midi is somewhat of a mystery to me and I just keep poking at it until it does what I need
PT9 + Mbox3 Pro Midi Port question + RTAS midi routing mrwolfe macOS 0 05-29-2011 11:24 PM
unable to setup MIDI instruments through Mbox 2 Pro MIDI port tomazbevilaqua 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 11-30-2010 06:04 AM
Digi 002R Midi Port 3 in Midi Studio set up hwsf12 MIDI 1 02-17-2010 09:10 PM
Hard to decide between Profire 610 and Fast Track Ultra.... JChance Pro Tools M-Powered (Mac) 0 02-23-2009 05:15 PM
Can't Decide on Time Sig for short track Matt Darcy General Discussion 4 09-05-2008 11:42 AM
