Old 07-10-2014, 10:33 AM
sebdj sebdj is offline
Default How to Have Automation on Section Only??
I look and try pretty much everything in the settings without success.
how can I make the automation ONLY to a specific region and LEAVE the previous/after track volume alone.
Ex : Let's say I have a 2 seconds fade-in gunshot sound, on a sound effect track.
The way automation work right now is :
by making this fade in/out to this specific region the previous /after also get a volume change
(unless I put 2 dots o each side of the region to block automation to happen outside that region)
This is really annoying to me and I think can easily lead to unwanted volume automation errors in session.
Is there a way (shortcut, setting) That we can LEAVE the rest of the track untouch when automating something?
Old 07-10-2014, 12:19 PM
Default Re: How to Have Automation on Section Only??
What I wish to do is exactly what is show in this Sonar Video at exactly 3:00 min : https://www.youtube.com/watch?v=R4ZuUbgmTrc
Notice how he modified only the section he wanted and left the remaining UNTOUCH.
Can we do that in Pro Tools?
Old 07-10-2014, 01:21 PM
Ben Jenssen's Avatar
Set the track to "Touch" automation mode and you should get what you want, I think.
Old 07-10-2014, 01:43 PM
Thank you for your reply but no It do not work
Old 07-12-2014, 05:38 AM
fork-media fork-media is offline
is it switchin to latch after writing?
are u recording automation? or are u drawing automation on screen?
editing I just use the "-" to switch to editing volume autmation..
then double click on a bite to create region selection an it automatically inserts the points when I move the 'whole line'
its only when drawing 'freehand' that the behaviour u describe happens.. so yes I do insert 'safety' break points as u describe..
2018 i7 3.6 GHz 6 core mac mini running monterey 12.6.2 - 32Gig RAM 512 Gb SSD drive
Focusrite Saffire PRO 40
Ultimate 2022 10 / HD Avid MC Mix / MC Control
Old 07-12-2014, 11:48 AM
I guess the technique you described is the best we can do with pro tools so far.
It just become a little tedious when the automation
fade as many regions to "double click" and blank space between them.
I found DAW like Sonar so much simplier when dealing with automation.
Your technique and CTRL Click (for safety points) is the solution i guess.
Thank you :)
Old 07-12-2014, 06:58 PM
if its just clip based volume. then clip gain works great for me
Old 07-26-2014, 02:35 AM
Changing the automation on a selected clip is easy.
and clip gain does pretty much the same (with some additional advantage)
But I'm talking about automating fade IN or OUT
between multiple clips (section) not the whole clip.
Old 07-26-2014, 09:38 AM
Extreme Mixing Extreme Mixing is offline
Using clip gain and creating fades on the clips should do the trick. If you just want to fade the clip, there is no reason to draw in volume automation. Additionally you could just set up a new track and then copy down the events that need to have a different setting. You could add automation, or anything you like, without disturbing the other track.
Steve
Steve Shepherd
Extreme Mixing
How to get PT to loop a section, without having to listen to that entire section? FranHoop Pro Tools 9 3 11-04-2011 02:57 AM
RECORDING SECTION BY SECTION jayrussell Tips & Tricks 3 04-28-2008 10:59 AM
how do i raise a section of automation? beau Pro Tools TDM Systems (Mac) 4 10-27-2001 01:53 AM
Ego section Tal General Discussion 0 04-13-2001 08:56 PM
"OTHER" Section digi-guy Digidesign Hardware & Software 4 10-17-2000 04:12 PM
