#271
New Hackintosh / PT7 monster HD PCI Rig
With a PCI interface right ? (Out of the Magma into the computer)
My gigabyte board has one PCI slot but I believe the deal is with the PCI's. (I don't use mine however) is it needs to be natively hosted by the chipset x79 or x58 I know that's the case with Win setups not sure about the hacks
#272
Re: New Hackintosh / PT7 monster HD PCI Rig
Anyone with any success on Jetway Q77?
Maybe you Lunar Eclips? If so, please share your experience, i'm also thinking of buying one next month.
Asus P5WDG2 ws pro Intel Quad Q6600 @ 2.40 ghz Corsair XMS TWIN2X2048-6400C5 G (4 x 2 GB installed) Win 7 / OS 10.8.2 Apogee Rosetta 800 192k PT10.3.2 HD |
#273
So, turns out, being the cheap and stubborn bastard that I am, most of my headaches were due to insufficient wattage PSU-simply not powering the cards. Got my hands on an old digi chassis and viola!-Core, 4x Accels & a Process light right up. Yay.
Have been getting the "cannot get audio fast enough" errors-periodically. and using intel HD graphics does result in unresponsive hangs from time to time. I did pull an nvidia from an intel mac I have here but, the machine would not even post and I didn't really ave time to dig ay further. So- more or less all good, but sadly, the other engineers in the studio are not as comfortable as I am with it: Jetway i7 2700K 16GB DDR3 OCZ Vertex 3 SSD boot WD 500GB audio drive. W7 ULT 64 PTHD 9.0.6 TDM PCIX (HD6) |
#274
Raoul Crane
www.blaze-studios.co.uk PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis |
#275
Completed a build with NAF93. Great mainboard. Installed 10.6.8 with 3770K, SSD Agility3, 16 GByte RAM (2x8Gbyte) and GT240. HD3 PCI-X fully working. PRO - UEFI (not 3D) bios and no DSDT needed - very fast boot, load bios and prompt for Chameleon in 2-3 seconds; PROBLEMS/TODO - no DSDT but still using nullcpupowermanagement - USB 3.0 not working at max speed, - OS freezes when plug USB3 and if xHCI enabled, ok if set to smart auto or auto (however not at max speed) - Internal audio not working! ALC662 recognized. Tryed also all versions of VooDoo driver but with no results. Used a 5 Euro USB audio. Hope this helps. |
#276
If so can you give the details... PT9 or PT10? SL or L? I'd really like to build a new Hack and the Jetway MB has lots of +s over the GA- P75-D3. Thanks for sharing. AQ.
AQ. Mac OSX Mojave 10.14.6 running Pro Tools Ultimate 2023.6 Mac OSX Mojave 10.14.6 running Pro Tools Ultimate 2022.9 Black Lion modified OMNI HD w/XB clock Multiple Black Lion modified 192 FM/XB interfaces Mac OSX ML 10.8.4 running PT10.3.7 HD4 PCIx (TDM & Native) |
#277
Just about ready to place my order for parts for my build, which is to be based upon the JetWay JNAF93-Q77 motherboard. I'm going to re-read this thread (among others) looking for your parts list in hopes of using your edited DSDT. I'd certainly appreciate any assistance you can offer to point me in the right direction...
#278
My New Protools HD System with GA-P75-D3
Hello guys it’s been a while. Last week my Jetway NAF92-Q67 blew away. I bought the GA P75 D3 v1.1 I Have it running with 10.8.3 and Protools 9.5. This machine has light speed and stable. I had to reduce some parts of the heatsink so the HD cards don’t hit the heatsink. Only you can run 3 HD cards on this board. The battery won’t let you put a fourth card un less you cut the contacts of your PCI card First thanks to Tonny, Macman and Squizo for tip on the heatsink My Rig GA-P75-D3 I7 2600K 16 GB Patriot G Series Sector 5 DDR3 1333 EVGA GT-520 2Gb Corsair H80 OCZ Vortex 3 SSD WD Caviar Black 1Tb (x2) Seagate Barracuda 1Tb Sony DVD Rom Cooler Master HAF-922 Protools HD 2 UAD 2 Solo 196 I/O Presonus Digimax D8 This is my guide Important Bios F9 Disable Intel Virtulization Technology Sata mode AHCI Super IO Cofiguration Disable Serial Port and Parallel Boot from Unibeat USB 10.8.2 Install OS Update to 10.8.3 and erase the AppleTyMCEDriver in S\L\Extensions if don’t erase it you will have PK. Multibeast 5.2.1 UserDSDT or DSDT-Free 887Audio\Realtek\WithoutDSDT\ALC887\888b Trim Enabler\ 10.8.1 if you use a SSD Network\Realtek - Lnx2Mac Bootloader\Chimera System Definition\MAcPro 5,1 Restart GT 520 Out of Box in 10.8.3 and the sound is working. Had no problem installing protools 9.5 It works awsome. Here is a video I made https://www.youtube.com/watch?v=Z-CbC8U7X_w I hope this might help. |
#279
Thank you Fredd, nice guide
can you confirm stability in this motherboard? PT sessions playing and recording without glitches . coz I'm about to build the same system with DH3 to my friend and he will run that in the studio. Thanks |
#280
Hi guys, I have my hack based on Gigabyte Ga-H55-USB3 and i7-3.07Ghz for sale. The Mobo supports Pro Tools HD3 on PCI-x - as reported here it works great and it's very hard to find.
I have this in a mac pro casing ready to be used, but alternatively, if you outside EU to reduce shipping costs I can sell the main components ad a package: Mobo+ i7 EVGA Gpu 16Gb Ram 128Gb SSD The SSD comes with OSX 10.6.8 and Pro tools HD 8/9/10 pre installed and tested. All you need it's a case and a PSU. Shoudn't be a problem to have these components shipped to the US as thy are not heavy and should fit into a reasonably sized box. PM me if interested.
GA-H55-USB3 SSD 120GB Mountain Lion 10.8 Pro Tools HD|3 Gigabyte GA-P55-USB3 i5-750 SSD 120GB Mountain Lion 10.8 Pro Tools HD 'Native' (no cards) |
Hackintosh for Pro Tools 7 - 7.4 anybody ? | zavid | Pro Tools TDM Systems (Mac) | 0 | 02-19-2014 03:51 PM |
Hackintosh Problem | pocketcalc | macOS | 2 | 07-08-2012 05:35 PM |
Hackintosh with PT9 HD Native? | PMedia | macOS | 9 | 07-11-2011 09:12 AM |
Hackintosh on my rig? | Raoul23 | Pro Tools TDM Systems (Win) | 7 | 07-01-2011 03:26 PM |
Hackintosh Help | HDK_Ent | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 07-16-2010 10:45 AM |
