Old 07-13-2009, 10:50 PM
Mitchell_Warters Mitchell_Warters is offline
Default Whats wrong with my Pro Tools 8
Can someone please help me
I cant do anything in pro tools without it giving me the system overload message. Even when my buffersize is set to its biggest and i have no plug0ins running it still does it.
When it does play through it sounds distorted for about 7 seconds then normal playback.
My system usage window tells me im only using 11% of my CPU power but it still says its overloading.
Help me please!!
Old 07-13-2009, 11:03 PM
nod25 nod25 is offline
Default Re: Whats wrong with my Pro Tools 8
This is normal for Pro Tools 8.
Hopefully a CS update will fix it :)
Why do people keep running over a string a dozen times with their vacuum cleaner, then reach down, pick it up, examine it, then put it down to give the vacuum one more chance?
Old 07-13-2009, 11:36 PM
ahk thanks
so i guess there is nothing i can do to temporarily run a session?
Old 07-13-2009, 11:45 PM
Originally Posted by Mitchell_Warters View Post
ahk thanks
Go through the Troubleshooting thread.
That's all Digi will tell you to do.
Old 07-13-2009, 11:52 PM
Nod25:
That was a pretty cruel response to a new person on the DUC. That's not the kind of impression we want to give new comers here. Let's try to be more helpful, ok?
Mitchell_Warters:
I have Protools 8.0 and everything is running fine so it is not fair to flatly claim that that is how Protools works. I'll admit that Protools is very particular about hardware compatibility and configuration. There are some things to do to make your system operate properly in the general troubleshooting sticky thread at the top of this forum. Try those and it should get you up and running in no time.
For starters, do you have a second hard drive on your system? It is one of the minimum requirements. If it is external, it should be a Firewire drive and NOT a USB drive. Trying to record and plaback from your system drive is a known problem that causes errors as the drive cannot keep up with the demands of Protools. There are also quite a few system tweaks that make your system optimized for Protools as mentioned above. Turning off wireless networking is the most common tweak. Follow the instructions in the Troubleshooting sticky and get back to us about how it goes. Most of us (ahem) are here to help.
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 07-14-2009, 12:25 AM
(ahem) Sorry.
Cruel? Hardly. Truth? Yes. Why beat around the bush. I did digress however. I did point him to the Troubleshooting thread on re-think to my original reply, as penance :)
Maybe he has a degree in computer science. It IS a requirement to run PT these days....
Old 07-14-2009, 02:39 AM
doubtful guest doubtful guest is offline
this is also the case for me. I have overload errors with 15% CPU usage and occasional distortion on playback. my system is 100% digi approved. I have done all the troubleshooting, clean installs, etc. I can not get 8 to run reliably for even small overdub sessions. I'm sorry to say that I have had very little constructive help from tech support.
The one thing I have found to help with this problem is to switch the rtas engine to one processor instead of two.(if you have a dual processor)
other than that, definitely run the protools prefs and database trasher in the troubleshooting thread and restart.
good luck
Old 07-14-2009, 03:32 AM
gruddlebug gruddlebug is offline
Wink Re: Whats wrong with my Pro Tools 8
Hello,
I'm using a White iMac Core 2 Duo 2.16Ghz 2Gb RAM MBox 2 Mini 64 Buffer
I set my RTAS processors to 1, I use NI Komplete 4 and others which need this setting until a software update becomes available.
The only time I get errors is when I switch plugins on the fly while a track is running.
If I dismiss the overload dialog and start the track again all is well.
I have a computer science degree, but it is certainly not required for PT8 (maybe a little research and patience)
Cheers
evs
Old 07-14-2009, 03:39 AM
BradLyons BradLyons is offline
My first thought here is actually two-fold..... ONE, you need to have a dedicated hard-drive for your audio that is NOT the internal hard-drive and NOT just any external hard-drive, and certainly NOT a USB drive. And SECONDLY, it sounds like it could also be file-fragmentation. When you have a fragmented hard-drive, that will be the direct source of "weirdness" including (especially) distortion of audio. You don't have a lot of RAM, is your model upgradeable to the 4gb or 8gb? If either, upgrade your ram....buy a Glyph FW hard-drive, and STOP switching plugins on the fly.
Thank you,
Brad Lyons
www.howavl.com
Old 07-14-2009, 03:46 AM
TOM@METRO's Avatar
+1 Don't do it.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
HELP! Whats going wrong abbypye 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-01-2008 02:51 PM
Whats wrong with my 002??? help buddha fingers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-21-2007 01:33 PM
Whats wrong with my 002??? help buddha fingers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-21-2007 10:51 AM
whats wrong with this pic????? KemikAL 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 05-30-2002 12:48 AM
WHATS WRONG WITH DIGIDESIGN.COM stickstome2 General Discussion 17 01-23-2001 03:32 PM
