Old 01-14-2007, 11:28 PM
beelofi beelofi is offline
Default Pro Tools Does Not Recognize M Box
Recently purchased Pro Tools 7.0 M Powered. I have the M Box 1814 Firewire. When I try to open Pro Tools it says no M Box is connected?! The program then closes. However, I'm getting playback with other music programs - Cool Edit Pro, Itunes, etc, so the M Box is definitely connected and working. Does anyone have a solution? Please help.
Old 01-15-2007, 03:03 AM
itsplayed itsplayed is offline
Default Re: Pro Tools Does Not Recognize M Box
Does everything look ok in the device manager?
Old 01-15-2007, 09:43 AM
SlowTools SlowTools is offline
First of all, the 1814 is not an M Box. But I think I understand you. If you installed the driver from the M-Audio driver CD, then that is your problem. You must install the driver from the Pro Tools M-Powered install disc, the one called FireWire Driver.
Old 01-15-2007, 10:21 AM
dillon99999 dillon99999 is offline
You should only install the driver from the M-Audio website.
Do not install drivers from any of the cd's that you received.
The website is the place that has the latest drivers.
Goto:
www.m-audio.com
Pro tools 8 doesn't recognize 192 i/o supafuzz macOS 8 01-14-2014 08:12 AM
Pro Tools HD 9 Doesn't Recognize 2nd 192 io oechols Pro Tools 9 2 05-09-2011 06:18 AM
Pro Tools can't recognize 192 I/O Juraj Bernáth Pro Tools TDM Systems (Mac) 5 11-03-2010 08:46 AM
Pro Tools LE does not recognize more than 1 CPU done_411 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 05-22-2010 06:32 AM
Getting Pro Tools to recognize Plug-ins jlnelson19 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-11-2002 06:10 PM
