Converting 24 bit to 16
Hi all,
Is exporting/bouncing in PT the best way to convert a 24bit filt to a 16bit or is there a better way of doing it ? cheers mac |
Re: Converting 24 bit to 16
Bouncing is probably the better method, because it allows you to choose what kind of Dither to put on the output before you bounce. Personally, I recommend either Pow-R Type 3, or Megabitmax (included in the Izotope Ozone plugin).
I have had to convert files in many different formats and sampling rates. A program called Barbabatch does batch conversions if you have a lot of files to convert and don't want to wait for a real time bounce.
I have compared it's 44.1 to 48k conversion(And Vice Versa) to protools and it is better than the PTool conversion. I would assume it would do a nice job dithering . I have not tried that yet. You might want to check it out. http://www.audioease.com/ http://www.audioease.com/Pages/Barba...rbaBatch4.html |
Barbabatch is better than pro tools conversion only with the release of BB v4. It should be noted that Pro Tools tweak head and bias peak are currently tied in a very close second place...and have been considered the best software SRC for years up until BB v4 came out. The audible difference b/w the two, in my opinion, is pretty darn slim.
Cavell Studios |
its called dithering...:)
If you don't like laughing at yourself, I will be happy to do it for you. Da-nick-str = Nick Dellos |
I wonder how Ptools 6.7's dither stands up to the BBatch? Does anybody know if they upgraded/changed it in 6.7?
I'm going to listen to the sample on bbatch's site before doing anything, but the waveforms look quite different, so I guess its worth the listen daniel |
Make sure you know the difference b/w dithering and SRC first...the two are really not related in any way and it baffles me just how many people on this forum use the two terms interchangeably.
Cavell Studios |
peace daniel |
Converting to MP3 | keytone | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 02-24-2009 05:54 PM |
mp3 converting HELP?!?! | steve.05251 | Pro Tools M-Powered (Win) | 0 | 01-28-2009 03:58 PM |
Converting from pc to mac! i need some help | mr razor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-16-2008 02:09 AM |
converting a WMA to a WAV ? | Pop-cycle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-13-2004 05:52 PM |
converting from 48K with PT | Grillo | Pro Tools TDM Systems (Mac) | 4 | 05-16-2000 03:53 PM |
