Pull up session does not effect output?
I had set the audio rate in the session set up window to 1% pull up for NTSC to Film but my output file is out of sync?
I see on the Bounce to disc there is an option (Pull Up Pull Down) for 48k but not sure witch to use, I guess 47952? If this is right won't the output file just be 47952hz? if I import this into a video app, won't it just play it back at 47952? Or will it get a 48k header written to it? Thanks, Mark |
Re: Pull up session does not effect output?
can you give more details? what rate is your session at? the QT is at 24fps? why the pull? up?
...normally, when you work at a straight 29.97 and have to go to film speed, you pull up. is this how you are working? otherwise, people have a 29.97 QT that was created with a 3:2 pulldown from 24. then you have a 30FPS sesion that is pulled down to 29.97 for NTSC watching and working, then pulled off for film speed file creation. you want the "layback" into the vieo app to be at 48k.
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
Session is set to 24fps, sound files are 23.98 or 29.97 (same thing) so in the "session setup" I have the "speed up 1%" selected to match my QT movie at 24-frame. Right now the sound files are to long when I do a "bounce to disk" When played on a video application so I need to speed them up just like there are playing in PT now. Thanks, Mark |
why isn't your seesion at 23.976 or 29.97? then you pull up to film speed. are you clocked to anything? do you have a sync i/o or big ben or lucid that will actually pull the rate of the samples instead of just the session? the actual audio is not pulled up without any external clock. right now, you are just pulling the "measuring stick" -- PT's timeline.
My session was at 23.98 until I made the final "24 fps movie" for film out and wanted to check it at 24fps because the video is now at 24fps.
I just need to bounce to 24 from these 23.98 Mark |
Thanks, Mark |
i commented above that the actual audio is not pulled without an external clock. do you have one? is it NOT PULLING when you look at the 24fps session and movie? if it still is, you'll be out of sync. if you don't have one, you haven't pulled the audio.
I do not have a external clock. What about the pull up on the bounce to disk dialog window? This is where I would think it would need to happen. Thanks, mark |
Help!
This still is not working! if I do a Pull up at Bounce to disk and then reimport it PT just converts it back to 48K and nothing has changed? What do I need to do to get this dam file to speed up 1%? Thanks, Mark |
Output Level - effect on tone | dmock66 | Eleven Rack | 13 | 09-22-2011 09:32 PM |
No pull down menu in Session import data? | Reitzas | Pro Tools TDM Systems (Mac) | 5 | 03-07-2008 05:34 PM |
My CPU Crashed, Now When I Pull Up My Session I Get This... | M2E | Pro Tools TDM Systems (Mac) | 1 | 02-25-2008 02:35 PM |
Converting a non-pull session to pulldown? | Starcrash | Post - Surround - Video | 9 | 11-02-2007 03:14 PM |
Session Setup Pull Up/Down question | Jay Nierenberg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-05-2004 11:51 AM |
