#4931
Re: i7 Builds - Specs and Results
Aaron Mulqueen - 001 HD Native |
#4932
We are not gamers or extreme OC geeks here. . Overclocking should only be considered if you can't or don't wanna upgrade your current processor right now but would like to gain a little more juice. You'll be fine with any new processor that gives you the power you need. |
#4933
Second, overclocking is not available or recommended on all processors. You need both the right motherboard and the right CPU (ie, modern Intel CPUs with a "K" have unlocked multiplyers). It's not likely that you could take a budget CPU and make it perform much better. Generally, you're already paying a few more bucks for a CPU you can actually OC in the first place.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
#4934
With the OP stating that most of the original system builds have had their components discontinue, updated or replaced: what are current mobo/CPU/ram parts that are verified the most stable with PTLE8? Is it a matter of me.finding one, maybe two builds that show good PT performance and copying their setup?
Um looking to spend $800 or less on mobo/CPU/ram. |
#4935
#4936
I gothcha- some folks I think are OCin just to see what they can get out of their machines. You're saying it can be used as a means to get get what you need out of a system while avoiding a costly upgrade. However, If you have a machine that exceeds the specifications for its intended purpose, then no need to OC.
Thank you, I think a lot of people will find that helpful-and probably fuel for discussion. |
#4937
I finally got all my parts and built my new DAW with the following components:
Intel® Core i7-3930K Processor CORSAIR Vengeance LP 32GB (8 x 4GB) 240-Pin DDR3 1600 Windows 7 64Bit Ultimate Edition ASUS P9X79 WS, Socket-2011 ASUS EN210 SILENT/DI/1GD3/V2(LP) GeForce 210 1GB 64-bit DDR3 Antec Performance One Series P183 V3 Black Aluminum LITE-ON 12X BD-R 2X BD-RE 16X DVD+R 12X DVD-RAM 8X BD-ROM Intel 520 Series Cherryville SSDSC2CW180A310 2.5" 180GB SATA III (1xOS) Western Digital Caviar Black WD2002FAEX 2TB 7200 RPM 64MB Cache (2xPTLE 10 & Backups) Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM 64MB Cache (1xSamples) Corsair AX 850W PSU Noctua NH-D14 SE2011 140mm and 120mm SSO CPU Cooler SIIG FireWire 2-Port PCIe Model NN-E20012-S2 Pro Tools 10 LE - Crossgrade Digi 002 I can't seem to get past the 300 DVerb Mark???? Dverb 1024 (w/ optimizations) = 300 with CPU(RTAS) at 89% I thought I would be getting way more DVerbs than that. Any ideas??? Configurations I have tried: Using Ghost 15 for backups throughout the process Updated BIOS to latest No Overclocking yet I loaded Windows 7, PTLE 10, Office 2010, Nero 10, Daemon Tools Lite, as my base build and took an image Avid's Windows 7 PT Optimizations Switch to X.M.P. - I think it's enabled by default, i didn't figure out how to set this Disable Speedstepping (C1E, C3/C6/C7) Disable TURBO MODE and speedsteppin Hyperthreading is on "Boot device priority" only checked my OS hard drive Disabled On-board Firewire, Audio, Serial, both LAN ports CPU Cores Enabled (Note) [All] CPU Thermal Monitor 2(TM2) (Note) [Enabled] Virtualization Technology (Note) DISABLED Seems like my DAW did better before a lot of the windows 7 tweaks? I must be missing some major setting in the bios or at the OS level, not sure at this point. Any recommendations are appreciated! Thanks. |
#4939
i would NOT reuse the power supply. this is one of the most important parts of the build. do not short yourself here!!! 650 w is fine, but definitely replace it.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
#4940
in the pro tools setups are you setting your machine to run on all but 1 of your processors??? it will probably default at 6.
Best Core 2 Series Desktops-Results and Specs | sunburst79 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2416 | 02-19-2013 07:49 PM |
new to pc builds | chazc080488 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 10-18-2011 07:10 PM |
any p45 builds | fofif5792 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-09-2008 12:47 PM |
OSX "builds" | Richard Barrie | Pro Tools TDM Systems (Mac) | 2 | 10-18-2004 08:37 AM |
