Old 10-07-2002, 07:32 AM
1511 1511 is offline
Default Copy a song section to another part of the arrangement?
Hello,
Does anyone have a method for pasting a song section to another place in the arrangement? ie. using verse 1 as verse 2 in the same track. My difficulty is aligning the pasted copy. There's probably a way to do this a lot easier than how I've been doing it
Thanks for any help,
Chas
Old 10-07-2002, 03:35 PM
nevadadad nevadadad is offline
Default Re: Copy a song section to another part of the arrangement?
I'm always reluctant to answer a question from work -- I don't have PT or the manual in front of me. And because I'm still a newbie. BUT...
The easiest answer is put the Edit window into Grid mode (see the four modes at upper left of Edit window) so your audio can be precisely selected. Grid mode snaps your cursor to the beat (1/4 notes are the default, I believe). Otherwise you're eyeballing where to click, and that's not good for the kind of repetitive accuracy you're wanting.
For example: select the chorus, starting at beat 1 of measure 09 (your cursor snaps right onto beat 1 if you're in Grid mode). Then copy it, then click onto beat 1 of measure 17 -- paste. MIDI works the same way, btw.
Old 10-07-2002, 06:31 PM
I know what you're saying about grid mode. These tracks I'm working on were recorded in from adat, so there is no PT click to snap to. Will the grid mode still work?
Thanks,
Chas
Old 10-07-2002, 09:08 PM
VillageGreen VillageGreen is offline
Grid is always there, but it's default until you set it and will have nothing to do with the song. If it's a stereo mix brought in from an ADAT, it's tough to set the grid to the new tempo precisely. My suggestion would be to set up another track, copy the 1st verse below the second and line up a drum hit or something else as a reference point using slip mode and zooming in very tight, once the verse is in time, select it and use control+option to grab it and move it up to it's new spot in the song. After that your next chore is to find the best spot for the cross fades.
God Save Mrs. Mopp
Old 10-07-2002, 09:43 PM
atools atools is offline
Assuming it was either recorded with either electronic instruments from a sequencer or recorded to a click track it's very simple to set up a tempo map and use the grid function in pro tools. Simply use the identify beat command (Apple-i on a mac) to mark beats and protools will automatically calculate tempo from these markers. Once this simple process is done you can use grid mode in bars/beats to simply copy and past your song together.
Copy and paste a whole section in PT8 Raoul23 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-25-2010 07:40 AM
How to copy one song out of a multi song session? Kevin Mowry 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-14-2007 11:36 AM
LOCATION MARKERS MOVE WITH SONG ARRANGEMENT? crizdee Pro Tools TDM Systems (Mac) 7 04-01-2005 03:01 PM
Set levels for one song/section JacobWeber 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-29-2003 09:25 AM
Importing a section of a song. duanebonney 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 01-02-2003 05:21 AM
