Bug - Telescope and Accordion warping will not snap to selected grid value!
This has been a bug for me on both 2023.3 and 2023.6
I'm sure we are all familiar with using the TC/E tool to stretch loop to fit to the session tempo? If you try to replicate this simple process with elastic audio (telescope warping) in grid mode, it will not work properly. If for example you try to take a one bar loop and stretch it to 2 bars with a telescope warp, the clip will not snap to the grid correctly at all! If you try this simple process you will see the bug for sure. The only workaround I have found for this is using slip mode and aligning the clip visually by zooming into the sample level and then trimming off excess from the right. This is unfortunately not completely accurate but you can get probably get close enough so that no one would notice. The same issue is present with accordion warping, where I cannot get a 1 bar piece of audio to stretch to to a 3 bar length total from dragging the center warp marker. Nonetheless, any other users dealing with this? I think many don't come across it because they use the TC/E tool for these types of edits but since I am trying to check out elastiquePro algorithm, I've come across this issue many times. Last edited by skylar_battles; 12-16-2023 at 06:44 PM. |
Re: Bug - Telescope warping will not snap to selected grid value!
Telescope and Accordion warping still not working for me in 2023.12. Anyone else having this issue?
Pro Tools Ultimate 2024.3.1 MacBook Pro 16" Apple M2 Pro with 12‑core CPU, 19‑core GPU, 16‑core Neural Engine 32 GB unified memory 1TB SSD storage Ventura 13.6.4 |
I have never run into this issue. What algorithm are you using? I use either pitch n time or élastique (paid version) to do this. I have never run into issues snapping loops to grid to adjust the loops tempo to the session.
Ej |
I'm just having the issue with telescope warping and accordion warping. TCE works, and so does "conform to tempo" All algorithms are equally effected.
I’ve started a support case for you on this under Case 04728703 Thank you!
-Tope To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support www.topedomingo.com |
Snap to grid | Neurosis | Pro Tools 12 | 4 | 05-26-2016 05:15 AM |
Edit Mode difference between: Grid and Slip+Snap to Grid | zenstone | macOS | 0 | 02-05-2015 04:34 AM |
Grid BUG - PT fails to snap to grid when zoomed out | 25ghosts | Pro Tools TDM Systems (Mac) | 0 | 04-18-2009 07:54 AM |
Snap to Grid | [email protected] | Tips & Tricks | 2 | 12-19-2008 10:16 PM |
6.4.1 Grid Mode often does not snap to grid???? | Philthy | Pro Tools TDM Systems (Mac) | 4 | 05-24-2005 03:25 PM |
