Old 05-09-2012, 10:23 AM
pie55 pie55 is offline
Default testing accel card
I bought an accel card that isn't working in my set up. Are there any other tests except digitest to verify that the card is in deed faulty?
I don't want to ship it back unless Im sure it's broken.
WIth the accel card installed I get error 4 then 9003 when loading Pro tools. Digi test won't even start with the accel. I tried swapping the core card with the accel. same error. I uninstalled accel card and digi test works fine with core card.
ANy help is greatly appreciated
Old 05-09-2012, 12:02 PM
Default Re: testing accel card
a question. Will an accel pcix card work in a standard pci slot? Im using a Asus k8n-dl mother board
Old 05-09-2012, 02:04 PM
please help. I'm going to use the sandra program to help trouble shoot but it would be great if someone could conferm that the accel card should work fine in a regular pci slot.
Any one?
Old 05-09-2012, 02:05 PM
nerd513 nerd513 is offline
sounds like u dont have the card installed properly make sure it is in the slot correctly
Old 05-09-2012, 03:28 PM
Thanks. THe card definitely is in the slot correctly. I tried with the core card in 1 and the accel in 2. Same error. core in 2 accel in 1... same error.
COre by itself... fine.
I really need the answer to my question " will a pcix accel card work in a normal pci slot? THat's the only thing I can think of to why the accel card won't work.
I'm going to try the sandra report for more info
Thanks for reading
Old 05-09-2012, 03:46 PM
i even tried uninstalling PT then re installing . same error
Also tried it on 2 different boots. same error
Old 05-11-2012, 05:54 PM
Brandonx1 Brandonx1 is offline
You have to attach the flex cable from port "b" on the core card to port "a" on the accel card.
Good luck
Old 05-12-2012, 12:36 PM
I tried connecting it properly as of the manual but in that configuration digitest wouldn't ever start.
I tried swapping card possition, same issue. I tried core by itself... Pass.
THen I tried the reverse order of connecting the flex cable. THis time digitest runs the tests on the accel card but it fails. In this configuration the core passes.
I'm trying to find a local studio that is using Protools 8hd pcix to see if the card works in their system before I return it.
Old 05-12-2012, 01:22 PM
here's my motherboard pci specs...2 x 32-bit/33MHz PCI
1 x PCI-E [x1 ]
1 x PCI-E [x16 ].
Is this pci compatible with an accel card?
Old 05-12-2012, 05:44 PM
1 x PCI-E [x1 ]
1 x PCI-E [x16 ].
Not sure about your motherboard. If you are running an unsupported system you are running an unsupported system. You might want to try a pcix expansion chassis. It only connects to the pcix or pic slot which works and connects all the digidesign pci had cards to it. You might have a Iraq conflict or you might have a bad accel card.
Process Card Question... Accel vs non Accel gsilbers Pro Tools TDM Systems (Mac) 13 05-22-2013 01:51 PM
Can I use PCI-X HD Accel Core card as HD Accel card? bad jitter Pro Tools TDM Systems (Mac) 5 10-18-2011 04:14 PM
Accel Core card vs. HD Accel card Scott Pilgrim Pro Tools 9 3 09-19-2011 03:15 PM
HD3 Accel 1 x interface Top Accel Card SuperReverb Pro Tools TDM Systems (Mac) 23 05-26-2010 01:27 PM
Testing for secons HD card GtrDude Pro Tools TDM Systems (Win) 5 03-28-2010 06:41 PM
