Old 10-15-2011, 12:41 AM
wdjudd wdjudd is offline
Default Connecting PC Formatted USB Drive to Mac
I have a client who wants to bring a PC external USB formatted drive [Windows 7] that I can connect to my Mac Pro [OS 10.6.7], so that we can transfer sessions back and forth. Is this possible? If so, what would be an appropriate drive type - i.e., OWC 500 GB Model No. . . , etc. Thanks for your assistance.
ProTools 2021.12, Lynx Aurora (n) 32 TB, Sibelius 23.2.0; OSX 10.14.6; Mac Mini: 3.2 GHz Intel Core i7; 64 GB 2667 MHz DDR4; Internal 2 TB SSD, External Sabrent TB 2 TB SSD
Also ProTools 2021.12, 002R,; Mac Pro: 2 x 3.46 GHz 6-Core Intel Xeon; 128 GB 1333 MHz DDR3 ECC; Serial ATA Drives (Journaled HFS+): 2 x OWC Mercury Electra 3G 2 TB SSD; 3 x Seagate Barracudas 1.0 TB; External Firewire Drives (Journaled HFS+): 4 x Seagate Barracudas 1.5 TB and 6 x Seagate Barracudas 1.0 TB
Old 10-15-2011, 01:35 AM
aasteveo aasteveo is offline
Default Re: Connecting PC Formatted USB Drive to Mac
You can drag and drop files to it, but you won't be able to work off of it. I don't think you can do a 'Save Copy In' on it either. If it's FAT32, it's drag and drop only.
Old 10-15-2011, 01:37 AM
Codo Codo is offline
Get the right software:
There are plenty. Personally, I´m quite keen on the NTFS-3G, as it has always worked perfect with every usb-hdd I ever connected. For write/read i mean, of course...
Old 10-15-2011, 10:42 AM
Thanks for your reply and input.
Just so I am clear . . . the following scenario will work: My PC client buys a new 500 GB drive from OWC (or other), formats the drive as NTFS?, he can then use it via USB 2 to record PT sessions onto the new external drive. He can then bring the PC USB drive to me and I can connect via USB to Mac with Tuxera NTFS installed, and copy his PC created sessions to my Mac internal drive, work with the sessions, and then copy them back to his PC USB drive? Is this correct?
Thanks for your time to answer my questions. Much appreciated.
Old 10-15-2011, 10:51 AM
Exactly, but I have never tried if Tuxera works perfect. If tried a few others but ended up using the one I mentioned above. It makes my Mac able to read/write on NTFS disks. Remenber to make the correct settings in your new icon in the bottom of System settings panel.
Hard drive formatted to?? barry1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-19-2010 08:42 AM
FORMATTED Drive PT 8.0 won't install now.... cary chilton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-31-2010 04:45 AM
Formatted wrong drive!!! Help!! soundeziner Pro Tools TDM Systems (Mac) 1 08-12-2007 05:15 PM
using windows formatted drive therecordinghouse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-03-2006 02:12 PM
PC-Formatted Firewire Drive on a Mac? fmckinnon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-21-2003 11:20 AM
