Midi track problem
Hy. I use a template on every project. The midi channels are set to 96.
I record drums ..., but somethimes after record one channel goes up to 127. Why ? Thanks! |
Re: Midi track problem
Don't know why it's happening but you might be able to get rid of it by opening the event list view for the track and deleting or changing the volume event at the beginning of the track.
Your template is probably set that way. If your talking Velocity (Midi volume). Then when you go to record it sounds different. Change your midi volume to be equal on both sides. see what happens.
My System Mac mini M1 OS X 11.6.4 PreSonus 1824c Faderport 16 Pro Tools Ultimate 2021.12 Studio One 6.5 Pro Logic Pro X |
Midi track problem | JayRay | Pro Tools TDM Systems (Mac) | 3 | 10-02-2012 12:50 AM |
Problem navigating after adding a MIDI track | mahler007 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-22-2006 05:09 AM |
Midi Track height problem | dubaifox | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-08-2006 07:27 AM |
7.2.1cs2 - Mix Groups (problem with Midi track) | Craig Timmis | Pro Tools TDM Systems (Mac) | 0 | 11-26-2006 11:55 AM |
Problem with track MIDI | rapidmind | MIDI | 2 | 11-16-2005 10:55 AM |
