Old 03-08-2010, 02:49 PM
Bender412 Bender412 is offline
Default Speakers POP when Control24 is powered up
I'm monitoring thru my Control 24, Using Mackie HR824s. I'm also using a Rosetta 800 as an interface for my HD system. So....
Out from Rosetta (DB25), to Control24 "ProTools Monitor In" (DB25)
Out from Control24 "Speakers Out" (DB25) to Mackies (Breakout TRS)
When I power up the Control24, I get a REAL loud, bassy POP in the monitors - even though they're POWERED OFF! This never happened when I prevously had the Mackies connected to an analog mixer.
Anybody know why?
Old 03-11-2010, 01:15 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Speakers POP when Control24 is powered up
Anybody know why?
You're getting a pop with the monitors powered off? that can't be right?? Where's the pop coming from then if the monitors are not powered up
Obviously you should always turn your monitors/amp on last!! and then turn them off first when shutting everything down.
If the monitors are powered down, then do you have a sub bass speaker? same applies for that? turn it on last, after you have booted pro tools and turned on the control surface.
Chris
Producer, Engineer,
www.ukmastering.com
Old 03-11-2010, 05:32 PM
netnoggin netnoggin is offline
Yes, the Control 24 has a healthy DC spike on the outputs when you throw the big switch. I just about jumped outa my shorts the first time I did it (had to duck as the cones flew by ). And BTW, the first time was the last time. As the previous poster said, get your power-up/power-down order right and it's a non-issue. I just needed a gentle reminder.
But if the speakers pop with no power applied, I would check for magic monkeys. Just sayin'.
NN, aka Hobonoggin
H.I.T. Program graduate (Hobo Internship Training)
Old 03-19-2010, 01:15 PM
Table Syrup Records's Avatar
Table Syrup Records Table Syrup Records is offline
Another classic DC harness issue
Assuming you're out of warranty....
look up one of the millions of threads about cleaning and reseating all the White DC Molex connections.
U should do them all while you're in there. And all the ribbons too.
At least do all the PSU DC connections and all connections on your monitor board.
And get used to it.
That or spend a stack on it, send it to Digi, have em go thru the whole thing.... fix any problems (Some u may not even know exist) and you'll get a new DC Harness too. :) WELL WORTH IT
Shorty: Table Syrup Records
Mac Pro 5,1 3.33 GHz Hex, 32GB
EFI Flashed - 5 GT/s Modded 7950, Dual Apple 23"
OSX Sierra
Pro Tools HD 11.2.2
Waves IOS, IOX, STG2412
Extreme Server (x2)
Logic Pro X, DSP Quattro, Final Cut Pro X
Waves Mercury+SSL+AbbeyRoads
Trident S65 with embedded US-2400
Live:
2012 Mac Mini, Dual SSD, i7 2.4, 16GB
Win 10, OSX Sierra
LV1, MRSG
Hardware from above (same gear)
Dual Dell P2418HT Touch Screens
Waves Icon X (x2), M, with Screens
Custom enclosure
Powered Speakers Gone Bad Larryboy General Discussion 4 09-19-2013 06:46 PM
Clearance sale, Protools HD, Speakers, Interfaces, Control24, Microphones etc etc SolidSoundSweden Buy & Sell 0 07-24-2013 10:40 AM
FRFR Powered Speakers? Vercingetorix Eleven Rack 36 08-03-2011 04:12 PM
Use of powered computer speakers DrewM 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-04-2005 02:27 AM
Powered Speakers GtrDude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 31 12-15-2003 08:21 PM
