Old 09-20-2006, 02:28 PM
crizdee's Avatar
crizdee crizdee is offline
Default distorted drum overhead advise
Received a project from another studio to mix and the right hand side of the stereo overheads is quite badly distorted, mostly the hi-end/hi-hat and cymbals! the lower stuff (the drums) is still probably usable. so i'm trying to decide whats best, should i duplicate the overheads and use a lo-pass filter on one track to give me overheads for just the lower parts(the drums!) then use just the left signal on another track for the cymbals, and hope the hi-hat track will balance out the right side of the overs??
Any other suggestions or thoughts
Chris
Producer, Engineer,
www.ukmastering.com
Old 09-20-2006, 04:03 PM
minister's Avatar
minister minister is offline
Default Re: distorted drum overhead advise
Sonic No Noise De-Crakle.
the amazing interpolator.
saved me when i had that.
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 09-20-2006, 04:20 PM
2fly 2fly is offline
Hi
I'm liking your thinking but I suppose you could always distort the other side to match then soften it all off and go for a dirty sounding kit. depends what sort of music it is I guess.
Alan
http://www.2flystudios.com
G5 2.5ppc, 4gb ram, OSX 10.5.8, PT8.0.1cs4
Old 09-20-2006, 09:05 PM
Mixchump Mixchump is offline
Hey Crizdee,
You could always try an MS decoder on the overheads. Try EQ'ing the distorted channel so that the top end is rolled off a bunch and use that as the 'M' channel (usually the left side in a stereo track), and use the clean track as the 'S' channel (usually right). What you'll get is a stereo result that gets wider when there's more activity in the clean ('S' channel), and more MONO sounding when there's not as much...
I use this trick sometimes for synth pads that have envelopes that are completely different between the left and right sides.
Hey, it's worth a shot...
Cheers, eh?
Old 09-21-2006, 12:01 PM
the dude's Avatar
the dude the dude is offline
if you have the space, re-amp the drums back out to the studio with some mic's
http://www.studio-techservices.com
าำ
[email protected]m
Mitch Berger Tech Services
We service ALL Avid products no Problem
HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything
ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around
inquiry using link above
Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear
Drum Overhead Mics firsty33 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-03-2011 01:19 AM
Drum kit overhead Mics KJVMBird 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 30 05-01-2006 04:35 AM
drum overhead question mbuono Tips & Tricks 8 02-18-2004 10:54 AM
drum overhead question mbuono 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-28-2003 10:00 AM
Drum OverHead Tips Kipsey Tips & Tricks 4 03-07-2003 09:29 PM
