Old 05-15-2012, 11:24 AM
pie55 pie55 is offline
Default asus k8ndl mother board with accel
Is there anyone using a k8n dl motherboard with opteron cpus with an accel hd2 system (pcix)
Thanks
Old 05-16-2012, 06:44 AM
Third Eye Studios Third Eye Studios is offline
Default Re: asus k8ndl mother board with accel
I only ran a Process and a Core card (windows XP), but I'm fairly confident an accel card would work. I still have the whole computer (minus HD cards) sitting in a corner in the machine room. It's our back-up rig I guess.
Old 05-16-2012, 11:47 AM
Thanks for the reply,
Additional info. In the device manager it reads hd accel and accel dsp as in working order but the accel card doesn't pass digitest and protools won't load giving me the error 4 then 9003
Old 05-17-2012, 06:29 AM
I'm probably the only other HD user that used that configuration. It was a pretty popular build for LE rigs at one point, and that's where mine started. Then I ran a HD2 non accel for about a year with little issues. But I didn't have an accel card at the time to try.
I'm thinking your card is probably bad. If you have the funds available, perhaps you could purchase another used card (pretty good deals on ebay these days), try it out in your rig, if it works, then send the other one back.
BTW, Did you have to "modify" the chipset fan to get the second card in? I did, otherwise the card would not seat all the way into the slot.
Old 05-17-2012, 12:22 PM
thanks.
I had to remove the chip set fan. Now I keep my computer tower open to keep it cool
Old 05-18-2012, 08:35 PM
Originally Posted by pie55 View Post
thanks.
I used a dremel to cut a little sliver in the plastic on the outside of the fan, just enough for the card to fit in, but I kept the fan on. Not sure if I'd remove the fan, that could burn up your chipset.
mother board help djmichael.london 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-06-2008 04:52 PM
Is this mother board ok? Dinos Pro Tools TDM Systems (Win) 1 05-29-2003 09:18 AM
mother board ? campabass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-12-2003 05:39 PM
Mother board Q hotrod468 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-27-2000 11:30 PM
what is your mother(board)? Johnba Pro Tools TDM Systems (Win) 4 08-30-1999 09:49 AM
