surround panner joystick
more and more we're getting gigs that involve surround mixing - and i'm growing tired of having to drag the little panning dot on the screen in order to write automation. does anyone have any experience with midi panning controllers like JLCooper Electronics surround panner option etc? we don't have a ton of money...so i might just have to live with what we have, but i feel like the midi controller would make the job so much more efficient.
thoughts? thanks in advance, paul
"It's locked when it's stuck to the 35 MM Print. Until then..." - - Dr. Sound ------------------------------------------------ pt hd 9.0.5 mac os x 10.6.7 2 x 2.66ghz dual core intel 7gb ram fibre drives via facilis terrablock video out - sdi mojo |
Re: surround panner joystick
I'm using that same JL Cooper midi joystick panner with a 2x2 midisport. WORKS FANTASTIC. I know Digi is coming out with/or already has a Midi panner based on the exact design on the Cooper model. Is that one out yet? Last time I saw it was at NAB a year ago. So, hopefully it's available.
Here is Digi's:
http://www.digidesign.com/index.cfm?...00&itemid=4955
Marti D. Humphrey CAS aka dr.sound www.thedubstage.com IMDB http://www.imdb.com/name/nm0401937/ Like everything in life, there are no guarantees just opportunities. |
What version of PT are you running? I thought digi dropped the non digi panners when they came out with their own. Best, Brandon
Brandon Howlett Vibe Audio Post, Inc. Re-recording Mixer Custom Build CPU, HDX 1, Omni, 192 I/O Digital S6 M10 24 fader Satellite Mac Pro, HDNative, 192 I/0 Black Magic HD Extreme |
I'm running 7.4cs5, OS X.4.9 on a G5 2.7 DP.
The "surround panner" profile in the SETUP>PERIPHERALS>MIDI CONTROLLERS menu works most swimmingly with the older JL Coopers. |
Best, Brandon
It should work fine since the Pro Control runs off the ethernet port and the joystick will be running off a separate midi/usb port.
thanks all. i guess there aren't very many options...which i guess makes the decision making process a bit easier. anywho - thanks again.
I have a question while we're on this topic. Can you map a MIDI CC message stream to control parameters of PT such as L/R and F/R panning?
I ask this because I'm planning (soon) to start running a PT rig along with Nuendo that I use now. In Nuendo, I can map MIDI messages to any parameter of the mixer/plugins, which allows me to use a Wacom tablet as a surround panner.
Danijel Milosevic |
MC Artist joystick panner? | cmaynes | Artist Series | 6 | 11-17-2012 12:02 PM |
usb joystick surround panner | electone | General Discussion | 12 | 06-09-2011 01:28 PM |
Surround panner: just a joystick? | cinetj | ICON & C|24 | 9 | 07-29-2008 01:27 PM |
joystick to control panner? | tomcat | Post - Surround - Video | 1 | 09-19-2003 09:23 AM |
Axis joystick panner & PT 5.1 ?? Help! | Jules | Tips & Tricks | 1 | 08-13-2001 02:30 AM |
