basic routing question
I'd like to use my 002's preamp along with an external comp/eq. What I would like to do is go:
mic--> 002 analog 1 in (to access the preamp on CH 1) --> 002 analog out ---> comp/EQ unit ---> 002 analog in --> to track on the hard drive I've never tried this before so I'm unsure about a couple things: 1. Should I use a send / return for this or some other method? 2. Is there a way to do it such that my signal remains analog for the first pass through the 002 so that I don't suffer additional conversions? Thanks. Charlie |
Re: basic routing question
1. Set output of mic track to analog 2. patch to ext gear. Record back in input 5-8.
2. get an outboard mic pre: micpre--->EQ/comp---> Digi line in 5 (or 6,7,8)
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
Thanks for the info.
I've actually been doing #2, with a relatively low cost tube preamp. Wanted to try my 002s pre for variety and to see what sounds better for vox and certain instruments. Regarding #1, if I do that will the signal remain analog the whole time or will it be converted to digital and back to analog on its first pass through the 002? Charlie |
I guess the question I'm really getting at is where the d/a conversion occurs. It must occur somewhere AFTER the preamp, no? I had been hoping the 002 was clever enough to bypass the additional a/d conversion when you route this way (thru the pre and out to a device before going to the track). I tried to find that in the reference guide but I couldn't find that question addressed there. Sounds like you're saying it is not set up that way and I'd suffer the additional conversion either way. On a somewhat related note... I guess in your case it doesn't matter (with the BLA mod). DO you find the converters to be perceptibly better? In what situations do you notice it most? Thanks. Charlie |
Basic Midi routing in protools Please:( | Flyingonempty | MIDI | 9 | 10-05-2011 01:54 AM |
basic midi routing for dumb newbies | wschuchner | MIDI | 3 | 12-31-2009 08:48 PM |
Routing out Logic 1 & 3, anyone know basic Logic routing? | soundonsound | Pro Tools TDM Systems (Mac) | 2 | 06-04-2008 10:42 PM |
Basic Midi Routing Question | dawtx | MIDI | 1 | 09-29-2006 10:05 AM |
Basic routing question - need to go to outboard digital FX | Burton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-26-2001 08:34 AM |
