#21
Re: Digidesign Digital 192 I/O internal 50 pin cables
Does the 1st AES CARD take priority over the 2nd card? If I am I a tracking session and not sending anything to the buses used by the 1st AES card I still cannot get any input from the 2nd card which is assigned to INPUTS in the I/O config. I'm not even using any analog inputs. Just trying to get 8 AES inputs from another converter using an AES D-sub (tascam AES) cable.
AQ. Mac OSX Mojave 10.14.6 running Pro Tools Ultimate 2023.6 Mac OSX Mojave 10.14.6 running Pro Tools Ultimate 2022.9 Black Lion modified OMNI HD w/XB clock Multiple Black Lion modified 192 FM/XB interfaces Mac OSX ML 10.8.4 running PT10.3.7 HD4 PCIx (TDM & Native) |
#22
You need to choose in the hardware setup. It is not anything automagical, but what you choose in the setup. You have more possibilities than the box can deliver so everything is up to you. What you decide.
#23
Am I not making myself clear? The 2nd AES CARD IS ASSIGNED (only the inputs) to the 1st 8 AES inputs of the I/O. The 1st AES CARD (slot 3) is assigned to AES 1-8 so there is a double up of sorts in the I/O config. Is this the problem? I would think not. I am not sending anything in or out of the 1st AES card and have even turned the reverbs off so NO signal or clock info is active down those lines. What am I doing wrong if this should work? Thanks again for your time. Anyone else care to chime in?
#24
So you have the standard setup (8 analog inputs, 8 analog outputs, 8 digital i/o) plus additional digital card which is 8 digital i/o.
You cannot just assume that plugging a cable to the interface somehow magically routes it to Protools. You need to choose what you use in the hardware setup! Possibilities are there. You just need to choose what you use!
#25
Am I not making myself clear? You need to go to the hardware setup and CHOOSE WHAT YOU WANT TO USE.
#26
I will check that this is configured correctly. Thank you for all your time helping me with this. It is truly appreciated!!
#27
No prob.
#28
What JFreak said. You have to configure with the HARDWARE SETUP first, then move to the IO page to 'route' where you want everything to go.
What you want to do is possible!
Eric Seaberg • San Diego, CA A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S. |
#29
Thank you both for your help.
Digidesign Cables + Apogee 16x = Don't fit? | BasketCase | Pro Tools TDM Systems (Mac) | 2 | 02-28-2013 10:45 AM |
FS: High Quality Digital XLR cables | Captain Audio | Buy & Sell | 0 | 05-22-2012 11:11 AM |
Internal SCSI Cables | DocDolby | Pro Tools TDM Systems (Mac) | 2 | 06-02-2008 02:43 PM |
please explain... digital cables (s/pdif) | 16yearsjeff | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 10-23-2005 11:03 PM |
Cables for Internal SCSI | goherbal | Storage Subsystems | 3 | 12-30-1999 12:18 AM |
