older sessions crash while loading PT 7.2
Am running PT 7.2 HD2 on Mac OSX 3.4.6, dual processor G4 running at 867mhz, with 768ram. I use external SCSI drives, as I have for years. Any new session is fine, I have recorded 16 tracks at once and had no problem or lag with recording or playback. Any PT 7.1 or 7.2 session loads fine from the SCSI drives, but anything older (and I have sessions running back to 5.1) causes a crash, always. Only ProTools crashes, the Mac says it's fine.
I have tried importing the old sessions into 7.2 rather than opening them, and that crashes as well. I have updated the ATTO firmware for the SCSI interface, and while I haven't gotten the legacy hardware recognized (1622 into a 96io), I don't think either are the problem. 7.2 loads fine by itself when it's icon is clicked. Anyone? Bueller? |
Re: older sessions crash while loading PT 7.2
I'm having exactly the same problems here, I mailed about it a lot with Digi Tech Support but nobody seems to be able to help me out... It is driving me crazy! I invested more then 150.000 USD in a PT HD 7 Accel and it is not even possible to open any of my older 5.1.3 sessions without crashing, it sucks big time! Sorry but I have to vent sometime...
Marc Schellekens http://www.deltamusic.be Mac G4 Dual 1,25 GHz (FW800) + ATTO UL3D + OSX 10.4.7 + PT HD 7.2cs1 PT HD 7 Accel (1 x HD Core PCI + 6 x HD Accel PCI) inside 7-slot 64 bit Digidesign PCI Exp. Chassis 192 I/O + 192D I/O + SYNC I/O + MIDI I/O + ProControl + Avid Mojo Apogee Big Ben + Apogee Rosetta 200 + Rosendahl Nanosyncs
Marc Schellekens Delta Music Belgium - Dolby Atmos Music Studio https://www.deltamusic.be Mac Pro 2019 - 3.2GHz 16-core - 96GB RAM - macOS 14.4.1 - PT HDX3 - Pro Tools Ultimate 2024.3.1 - Avid HD I/O 16x16 (x2) - Avid HD I/O 16x16 Digital - Digidesign 192 I/O - Digidesign 192D I/O (x3) - Avid SYNC HD - Apogee Big Ben - Apogee Rosetta 200 - Avid S3 - Slate RAVEN MTi2 (x2) - iConnectivity mioXL (x4) - Genelec ‘The Ones’ 9.1.6 Dolby Atmos Music monitoring (AES/EBU) with 8341A (x5) + 8331A (x10) + 7360A (x2) + 9301B - Almost all available AAX-DSP plug-ins |
I've had this before, and while I'm sure Digi is working on a fix, here's a way around it.
From my experience, older sessions my contain illegal characters or have minor glitches in the session file that 7x cannot deal with. If you are able to open up the session on an older system that has ProTools 6 on it, there's a pretty good chance that the session will open (session file is fully forward and backward compatible from 5.1 to 6.9). Once it's open, do a 'Save Session Copy In...' and choose .WAV as the file type, 24bit, select +12 faders, and make sure you 'Copy All Audio'. This will ensure that the session file and audio files are quite different from the original. Now, there's a good chance it will open on 7x. Give it a shot... Cheers, eh? |
I'm well aware of this workaround, as a matter of fact I still have my old PT 24 MIX 4 with 5.1.3 that I used for the last 6 or 7 years to do this, but I can assure you it is a real hassle to fire up my old rig to do a 'save session copy in' each time I want to use an old session in my shiny new HD 7 Accel...
But I thank you for the tip anyway Cheers!
Ooof! That can't be the only solution out there, can it? I'm talking about dozens of sessions I would have to convert and resave. Is there some sort of Force Convert patch in the works? Does it have anything to do with the speed or model of the Mac?
I appreciate the suggestion, horrifying as it is. Thank you. Why do I suddenly feel all depressed about spending all this money? |
I share your feelings, as stated in my initial reply
I do not think the problem is machine or speed related, I managed to track it down to at least one or more of the following events: - it has to do with AIFF files (most of the time split stereo) - it has to do with the naming of files (illegal characters) - when you do a 'Get info' on these files it states 'open with Quicktime' (or iTunes, or logic Pro, etc...), if you change this manually to 'Pro Tools 7.2' sometimes they do seem to load without crashing PT HD 7.2... Btw, no change in PT HD 7.2cs1 !!! (which I hoped for so much) For the time being this is all I know for sure and the only solution still seems to be to do a 'save session copy in' with PT 5.x or 6.x.
Older sessions opened cause Pro Tools to crash in 10.1.1 | B Stewart | macOS | 3 | 03-23-2012 09:41 AM |
AutoTune 5 Crashing Pro-Tools loading older sessions | KingFish | Pro Tools TDM Systems (Mac) | 1 | 12-16-2010 02:19 PM |
Older PT Sessions not loading in 8? | Musepro | Pro Tools M-Powered (Mac) | 2 | 07-17-2009 08:04 AM |
Older PT Sessions not loading in 8? | Musepro | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-17-2009 08:03 AM |
Strike not loading in older sessions since moving to PT8 | Che_Guitarra | Virtual Instruments | 2 | 01-12-2009 02:43 PM |
