Old 04-26-2007, 05:12 AM
Kon Alexiou Kon Alexiou is offline
Default Sole & Mute buttons
Why is that all of a suddent PT will only play back tracks on which I've clicked the Solo button? It didn't used to do this & I can't understand why....
Thank you.
Old 04-26-2007, 07:25 AM
sbag sbag is offline
Default Re: Sole & Mute buttons
i would like to help, but i unsure what you're trying to say, explain
a little better
Gear>
C8, 002, Trigger Finger, Kontrol 49, Apc 40
SW >
Pt 8, Reason 5, Recycle 2.1, Ableton Live Suite 8.02
Plugs >
All Registered plug in's & Vinyl out the wazoo. Mp3 sucks
a little better
Gear>
SW >
Plugs >
Old 04-26-2007, 07:41 AM
spkguitar's Avatar
Check to make sure all of your tracks are currently visible, and that none of them are already set to solo mode. If a track was hidden and it was in solo mode it would cause this behavior.
Old 04-27-2007, 05:00 AM
Hi Sbag,
Ok this is the situation:
I have about 15 tracks that I've recorded for the song I'm working on. They're all showing in the mix window and when I play back I can see there is a signal showing.
As for audio, I can only make each individual track play back simultaneously with the other tracks If I've enabled the Solo button on each track.
The mute button is not enabled so why do I need to enable to the solo button on each of the 15 tracks just to listen back to everthing simultaneously? Previously all tracks that were showing would just play back when I clicked the play button. If I enabled the solo button on a particular track PT would single out that track & play it individually.
Any suggestions?
Thanks.
Kon.
Mute / Solo buttons... ALL on or OFF RonInLA12 Pro Tools M-Powered (Win) 0 01-04-2013 11:51 AM
Mute buttons refuse to stay on...? Gothboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-19-2008 01:56 PM
MUTE AND SOLO Buttons are LOCKED! Joseph87099 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-13-2008 05:01 PM
help problem with mute buttons DeltaBeats 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-10-2005 06:26 PM
mute and solo buttons linked up! ijnad51 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-02-2005 01:41 PM
